On our first trip, I tried out several features of the new TT, even though we did not really need them.
When I filled the fresh water tank and started the pump, it was really loud! (Of course the DW was resting in the TT at the time!) Is this normal? My pump appears to be mounted to the floor inside one of the kitchen base cabinets, and it just seems to vibrate everything. Can anything be done to make it quieter?
I don't think we will use it very often, but just wondering if the noise is normal.
It is easy to insulate the water pump from loud vibration by using foam and transparent flex tubing. If you go to "search" and look for "Water pump problems" or related subject matter, you should be able to find some specifics as to how to deal with this problem.
Common problem. If it is hard plumbed, try installing a section of flexible water line instead. Next step is to put some isolation between the pump and floor.
Look at the photos below and add any or all of the modifications - each one will make your pump a little quieter... Mods consist of:
Noise isolating mount
Flexible input/output lines
Accumulator tank (the bigger the better)
Foam pipe insulation over rigid runs of waterline that are in contact with the floor, walls, etc... The last picture is not quite representative of this but gives you the general idea... I insulated this run of water line as it was transmitting a little vibration... I also use this method where water lines penetrate the floor at the kitchen sink, bathroom sink, etc... My pump is so quiet I cannot hear it run unless I am standing right by it...
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
Mine was loud too. I noticed that a stiff hose, coming from the pump, was touching the wall, banging like a drum when it ran. I replaced the hose with a softer one and put a curve in it and also kept it from touching the wall. This helped.
Les, When you drain your water tank at the end of each trip, is there an additional step because of the holding tank you added? Or is it just the same as if it weren't there? Does it just take longer?
Deb
Steve and myself
our 4 kidlets, Justin-14, Rachel-12, Michelle-10, Kellie-7 yrs old and
our Yorkie Tiffany-3
2002 Black 1500 Avalanche 4X4
2007 Sun Valley Road Runner 210 bunkhouse
exscream wrote: Mine was loud too. I noticed that a stiff hose, coming from the pump, was touching the wall, banging like a drum when it ran. I replaced the hose with a softer one and put a curve in it and also kept it from touching the wall. This helped.
That was where my noise was coming from and it sounded like some one hitting the floor with a hammer, but it was from the PEX tubing banging around. I put a little foam under the first fitting where the vinyl discharge mated to the PEX tubing and then secure the PEX tubing to the floor with one of the electrical conduit clamps about 2 inches past the foam and 90% of all my noise was gone. I also made sure the vinyl tubing wasn't allowed to rest against anything. Now it's actually too quiet and I can't hear it cycle in case I have a leak somewhere.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974. TRAILER MODS
