saltriver
phoenix, az.
I am on an extensive trip and presently sitting 70 miles South of DC at Flying J. Can anyone recommend a reputable tire dealer in the DC area where I can get a front end alignment and 2 new tires? I will be at Cherry Hill for a week so have time to setup appointment. Seems my front tires are wearing on the side of the tread on the outsides so I am thinking alignment problems? Plenty of meat in the middle as I only have 26K on these-rears look good. Any opinons welcome as I am not sure how far i want to trust these puppies beyond Dc-will also be in PA for a week before going to Liberty Harbor in NYC if anyone can help in that area.Thanks.
Bob & Sue (Driverman & SignLady)
2004 Allegro Bay 34xb
2008 Jeep Liberty
wolfe10
Tell us what chassis you have and what size/brand/age tires.
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
saltriver
phoenix, az.
W22-Michelin 235/80 22.5 XRV
ohdh
Schnecksville, PA
If you are traveling in the Allentown, Pa., area, help can be found. There are tire shops available and there is a very good alignment/spring/frame shop in Allentown. There are also one or two good campgrounds available a few miles away. If you need something while in the area, let us know.
saltriver
phoenix, az.
Planning on staying at the Allentown KOA, born and raised in Easton area (8 years) and will be checking out the old area. Any references will be appreciated, not sure I can wait until then but it isn't to far from DC and would rather deal with someone that comes recommended. If there is a better campground then the KOA I would also like that info.Tanks.
Gonnacall
WV
In Frederick MD there is Donald P. Rice tire right off 70 who does front end alignments and sells the tire you need. I would call them before ou go as I had to order the tires before I went (I needed 6 of them). The Front end guy there is proably one of the best in the state.
2001 Journey DL - Cat 330
J Walker
Oakton, Va
A large tire dealer on I 95 just south of D C is Albans, 703 455-9300, and they will either do alignments or refer you to a place that does them. If you are traveling I 66 Patriot, 703 753 7002, it a little west of Washington DC. They will do alignments but not tires.
edited 04/23/08 07:29am by J Walker *
Jim Walker
2000 34' Damon Ultrasport DP
1999 Cutlass
Brake Buddy
-Gramps-
Portsmouth VA
Are you sure your tires are not underinflated? The edges will wear out faster if they are as little as five pounds low.
___________________________________________
08 Holiday Rambler Vacationer 38PLT Workhorse UFO GAS Pusher Chassis
06 Saturn Vue toad, SMI Breaking sys,Blue Ox tow bar. Myspace site and blog
Gramps and family
Drive a UFO.com
RollinRock
SE Pa
If you make it up to Allentown on your current tires give Dave's Auto and Tire Center a call (in Souderton, PA off rte 309) at 215-721-7911. I'm heading there today for 16" Michelins for the rear. Had the fronts done a year ago. Honest and the prices are fair. I use him to inspect the MH and feel better after he looks at it.
Good luck,
Bob
427435
Rochester, Mn
Unless all the tread is gone on the edges, why do you need more than an alignment?
Mark
2000 Itasca Suncruiser 35U on a Ford chassis
2003 Ford Explorer toad with US Gear brakes,
ReadyBrute tow bar, and Demco base plate.
