RV.Net Open Roads Forum: Need online source for IPD sway bar bushings
 > Need online source for IPD sway bar bushings
Cousin_Eddy
Peoria, AZ
Posted: 04/22/08 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
Does any one have a link to an online source for IPD sway bar bushings? The ones I need are the 109-109. I don't really need an all new sway bar and rear bushings (Stage 1 kit). I found a source for that. I just need the front replacement bushings. Thanks!
1995 33' Southwind Fleetwood Model LW
wolfe10
Posted: 04/22/08 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
Roadmaster (the same people who do tow bars) bought IPD Suspension Division several years ago.
http://www.roadmasterinc.com/vehicle_guide/
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
Cousin_Eddy
Peoria, AZ
Posted: 04/23/08 11:34am Link  |  Quote  |  Print  |  Notify Moderator
I found these Moog bushings. They are "thermoplastic" which makes me think they are polyurethane, not the rubber ones like the OEM.
MOOG Part # K7326
K7326
They are only $15 for a set of two at Rockauto. Need two sets to do the replace the front sway bar bushings on both the arms and the frame.
I don't really think I need to change to a larger sway bar on this P30. There is up to 1/2 inch of play in these OEM bushings. Replacing these should make a huge difference.
Do you concur?
wolfe10
Posted: 04/23/08 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
I am not suggesting that you change sway bars. Roadmaster also sells quality polyurethane bushings for OE bars. CALL THEM.
* This post was edited 04/23/08 07:32pm by wolfe10 *
Cousin_Eddy
Peoria, AZ
Posted: 04/23/08 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
OK Thanks!
TDInewguy
Minneapolis, MN
Posted: 04/24/08 11:22pm Link  |  Quote  |  Print  |  Notify Moderator
Check out:
www.ipdusa.com
they sell a lot of parts for volvo, but also MFR the sway bar stuff.
SSSStefan
2006 Chev 2500HD - Crew Cab D/A
2005 VW Passat TDI wagon - tow vehicle for the pup!
2005 Fleetwood Allegiance
The most important thing you will ever do - www.claybe.com
wolfe10
Posted: 04/25/08 06:58am Link  |  Quote  |  Print  |  Notify Moderator
TDInewguy wrote:
Check out:
www.ipdusa.com
they sell a lot of parts for Volvo, but also MFR the sway bar stuff.
Nope, IPD USED (past tense) to do exactly what you say. But they sold their HD (non Volvo) suspension division several years ago to Roadmaster. Both companies are in the Portland Oregon area and many of the personnel involved in the HD suspension end of it moved from IPD to Roadmaster.
I toured Roadmaster's HD Suspension Component manufacturing facility last summer just before the summer FMCA Convention in Redmond-- it is indeed impressive.
KOG
Winterville GA
Posted: 04/25/08 07:16am Link  |  Quote  |  Print  |  Notify Moderator
You really do need a larger front bar on a P-30. BTDT.
Cousin_Eddy
Peoria, AZ
Posted: 04/25/08 10:13am Link  |  Quote  |  Print  |  Notify Moderator
I purchased those Moog "thermoplastic bushings". $15 per set....can't loose. I will try them out. I'll get a bigger bar if there isn't much improvment.
Cousin_Eddy
Peoria, AZ
Posted: 05/05/08 11:08am Link  |  Quote  |  Print  |  Notify Moderator
I installed the Moog "thermoplastic" front sway bar bushings. It made a noticable difference in sway. They were easy to install and cheap. Why would you ever buy the IPD bushings for twice the price?
