RV.Net Open Roads Forum: Foam Swim Noodles Under Your Slide Toppers
 > Foam Swim Noodles Under Your Slide Toppers
Ruth & Edward
Indiana
Posted: 04/22/08 10:34pm Link  |  Quote  |  Print  |  Notify Moderator
Just a timely tip.....
Are you looking for a way to prevent rain water from puddling on your slide toppers (awnings)? Are beach balls too big to fit between the top of your slide-out and the underside of the topper?
This was my situation last fall, when I hit on the idea of using swim noodles. However, being the wrong time of year, I went from store to store - probably 15 to 20 stores in all - unable to find any. Swim noodles are a seasonal item, and all stores had cleared them out by the end of summer.
Well, guess what folks! Swim season is fast approaching. I went to Wal-Mart today and, sure enough, I found them, in two different sizes - both are five feet long; one size is 3.5 inches in diameter and priced at $3.88; the other is 2.5 inches in diameter and priced at $1.50. I bought four of the bigger-diameter noodles; one for the bedroom slide; the other three, I'll cut to the right total length, then rope them together for the living/dining slide (the noodles have a hole that runs down the center of them).
My fiver is in storage a half hour away, and it is parked too close to the unit next to it, so that I won't be able to fully extend the main slide to do a test fit until mid July when I plan to use it next. But, I can fully extend the bedroom slide while in storage, so I will be able to test fit that one when I'm out to my unit next week.
I'll report back after I've had a chance to try these out.
2006 Ford F350 V10 2WD SRW SuperCab Short Bed
2005 Sunnybrook Titan 30RKFS Fifth Wheel
Adam-12
Northern CA
Posted: 04/23/08 12:01am Link  |  Quote  |  Print  |  Notify Moderator
I think it would be better if you posted some pictures on what you're trying to describe. Sounds like a good idea....I think. Pics sure would help us get the idea your trying to convey.
Thanks.
2008 Silverado 2500HD Duramax/Allison DIESEL/4x4/CC/Z71
2008 33ft. TT/BH-Super Slider
Parallel Honda EU2000i's
Yaesu 857d
Dipoles/random wire/tuners
Fishing equip.
Quads
Life member: NRA
ALCOHOL
TOBACCO
FIREARMS!
AGRNBRTSLOVE
NJ,USA
Posted: 04/23/08 06:21am Link  |  Quote  |  Print  |  Notify Moderator
I know exactly what you are talking about. You slip them up between the slide topper and the outside top of the slide to help with the rain runoff. Just remember to remove them before you retract the slide! We use them too. They're cheap, durable, and don't weigh much to store.
Wherever I happen to park
Posted: 04/23/08 06:49am Link  |  Quote  |  Print  |  Notify Moderator
The Swim noodles are big Styrofoam pipes Come in assorted sizes,colors and even shapes, Very useful for all sorts of things I'm not sure they would work under the slides
Someone makes air pillows to work under the slide awnings, Wedge shaped, I'm considering them.
sandmangw
Virginia
Posted: 04/23/08 07:40am Link  |  Quote  |  Print  |  Notify Moderator
They work great in cabinets and refrigerators to keep stuff from jumping around, too.
fulltimer5er
Central Vally
Posted: 04/23/08 07:45am Link  |  Quote  |  Print  |  Notify Moderator
Best use for them is on the slide corners so you don't split your gord when walking up to it in the dark
2005 Dodge one ton duely quad cab navagation system don't want to get lost before were ready to
2005 Carriage carri lite 36 KIQ four slides {HOME}
campkrazy
Fortson Ga.
Posted: 04/23/08 08:07am Link  |  Quote  |  Print  |  Notify Moderator
I saw a few campers with these on there slides in Florida last week.
Looked like a good thing.
Karen
My Pics
CactusJohn
Scottsdale, AZ
Posted: 04/23/08 08:22am Link  |  Quote  |  Print  |  Notify Moderator
I got tired of cracking my head, so I put them along the entire bottom edge of the bedroom slide. The bleeding has stopped!
2007 Ameri-Camp Summit Ridge SF27RK 5er
2008 F250 Lariat SuperCab, 6.4L PSD
Reese 16K Kwik-Slide with BedSaver
Vulcaneer
Northern New England
Posted: 04/23/08 09:03am Link  |  Quote  |  Print  |  Notify Moderator
If you use beach balls, only partially inflate them. Half full works for me.
Have seen some that place a stick of firewood on the topper to allow water to drain and keep them from blowing. That way if they forget to remove them, they just fall off, when the slide is pulled in.
2006 F350 V10 4X4 SC SB SRW 4.30 22,500 GCWR
Keystone Sprinter 33'9" 12,500 GVWR
Pullrite Super Glide 18K
Super Duty, Super Cab, SuperGlide
SEE RV.net Classified for Vette Description
Ruth & Edward
Indiana
Posted: 05/05/08 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
UPDATE!!!
This past Friday, I went out to the storage lot where I keep my fiver - to do a test fit of my new “anti-pooling devices”. I’m pleased to report that the 3.5” X 5' noodles were the perfect size for my application.
It appears I’ve solved my pooling problem. As a side benefit, since the noodles take up the slack in the slide toppers, I should experience reduced less flapping in the breeze.
