RV.Net Open Roads Forum: Folding Trailers: Air Condition Help Please
 > Air Condition Help Please
OLd-Man1
New Port Richey, Florida
Posted: 04/23/08 04:14am Link  |  Quote  |  Print  |  Notify Moderator
Hello I have a 07 Fleetwood Highlander Sequioa popup. The air works great, but at night when it cools down out side and when the air shuts down. Does the fan suposed to stay on all the time ? Thank You for any help with this subject.
Mike
2003 Ford Sport Trac
2007 Fleetwood Highlander Sequoia
MI Director
Michigan
Posted: 04/23/08 05:38am Link  |  Quote  |  Print  |  Notify Moderator
Yes!! Just like a standard window A/C unit. The duct air with separate thermostat controls are the only ones designed to shut down when temp. is reached.
djevans
Tennessee
Posted: 04/23/08 05:45am Link  |  Quote  |  Print  |  Notify Moderator
OLd-Man1 . . .
Most units I've encountered, including ours, can be set either way. The fan can be set to cut off with the compressor, OR, set to stay on and circulate air.
Some RV'ers are awakened by the "blower" (fan) cycling on and off each time the compressor comes on.
Don . . . near 36.171N 086.784W, TN near here
WA4ZFN
2003 Fleetwood Revolution 40C - Saturn VUE
350hp Cummins ISC
- - - P i c t u r e s - - -
I'm confused, WAIT! Maybe I'm not!
wayne_tw
South Dakota/Georgia
Posted: 04/23/08 06:15am Link  |  Quote  |  Print  |  Notify Moderator
This is the correct answer!
javaseuf
California's Gold Coast
Posted: 04/23/08 08:04am Link  |  Quote  |  Print  |  Notify Moderator
And this is the correct answer to the correct answer.
If your controls are located directly on the ceiling plenumn, then the fan will run all of the time. It will be the comressor that cycles on and off only.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
djevans
Tennessee
Posted: 04/23/08 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
Wayne_tw . . .
In many cases, you've "incorrectly" identified the "correct" incorrect answer, NOT "necessarily" the correct answer.
In two different cases, while touring other RV's with their owners, they said "something" to the effect, that one of the only things they didn't like was the AC fan waking them up when the compressor came on at night. I asked them why they didn't turn the AC fan switch to "circulate," "fan on," continuous, etc. or what ever verbiage they might use. They said they didn't have that ability. In both cases I found a "fan continuous on" switch position on both.
It's on a great many RV's.
One other thing re: window units. Several models of them can have the fan cycle as well.
OLd-Man1
Posted: 04/24/08 06:41am Link  |  Quote  |  Print  |  Notify Moderator
Thank you all for your fast responces. This help me out a lot. The unit I has a seperate knob for compressor which shuts off when desired temp is reached. The fan stays on all the time. But it has two setting for the fan Hi and Low and two setting also for the compressor Hi and Low. Thanks again for all your help. I am a newbe when it comes to this stuff.
OLd-Man 1
Mike
