Jogeo48ca
Fort Erie Ontario Canada
Hi All;
I was reading through messages on here some time ago, and I came across a post about leveling an RV with hydrolic balloons. I think that's what they were called. does anyone know what I'm talking about?Or does anyone know of anything that would make leveling our 5th wheel easier?
azjeffh
Chandler, AZ
I believe they were called Levelair and the manufacturer went out of business. I find carrying two 2 x 10's works for me.
Jeff
Wonderful wife Robin, no children, no pets, no money
05 F250 Supercab SB PSD w/Tow Command
05 HR Savoy 29RKS
skipnchar
Topeka Kansas USA
You could no doubt use any kind of lifting type bag with either air (would seem to make a very bouncy platform) or fluid but I can't even IMAGINE why anyone would want to take that much time doing something that could be done in a couple of seconds with planks or only slightly longer using leveling blocks. Good luck / Skip
CactusJohn
Scottsdale, AZ
I find using the Lynx Levelers quick and easy.
2007 Ameri-Camp Summit Ridge SF27RK 5er
2008 F250 Lariat SuperCab, 6.4L PSD
Reese 16K Kwik-Slide with BedSaver
BrokenElbow
Valencia, CA
I like my levelairs and when they wear out I'll probably build my own. Here's a set of instructions if you want to give it a try. Build your own levelairs
2006 Cougar 294RLS TT - 2008 F350 Lariat 6.4L diesel 4x4 SRW SB. Reese WD w/HP Dual Cam, 2xHonda 2000i,Rotochoks,Levelairs,Toppoprails bike rack
estesbubba
Omaha, NE
skipnchar wrote: You could no doubt use any kind of lifting type bag with either air (would seem to make a very bouncy platform) or fluid but I can't even IMAGINE why anyone would want to take that much time doing something that could be done in a couple of seconds with planks or only slightly longer using leveling blocks. Good luck / Skip
The air bags are not bouncy at all. They take a couple of minutes to pump using a foot pump and take practically no storage space.
--bubba
2008 Keystone Cougar 291RLS 5er
2006 Dodge Ram 2500 QC CTD, 4x4, 48RE, Line-X
Draw-Tite 16K Slider, BedSaver, Prodigy
our website: our trips | my woodworking hobby
malojeer
Cullman,AL
I built my own set of levelaires and use them every time. I use a cordless compressor from walmart. Just set them on the ground, back over them and fill to level. Easier then dealing with carrying blocks around and then I can't get them at the exact height I want
