RV.Net Open Roads Forum: Travel Trailers: Equalizer bars flopping around
 > Equalizer bars flopping around
BillB800si
S.E. MICHIGAN
Posted: 04/23/08 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
We're traveling down the Freeway today and a car pulls up and says a bar is hanging loose on the right side.
Pulled over and take a look and sure enough the 1400# torsion bar had slid over top of the L-Pin and was sticking straight out the side of the hitch.
Luckily we carried a Equalizer "Lost Pin Survival Kit".
Spare Kit
Was able to compare the old L-pin with the new one and noticed right off the old one was bent out a little. The new one has a sharp 90° angle to it.
Just a heads up for all you Equalizer users.
BTW, the hitch is only 2 years old and the other side L-Pin shows it's been bent a little also. Buying 2 more kits so I'll have a spare.
Happy trails,
Bill B. (Michigan)
2007 Dodge Ram 2500 MegaCab CTD
2007 Jayco Eagle TT Model 322FKS
Chuck&Gail
In the Colorado Mountains
Posted: 04/23/08 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
What is your tongue weight? All the bar tension is pushing DOWN, so it is hard to see how bar could go UP over pin. Not saying it didn't happen, but it sure must have been quite a bump for bar to go up that hard, unless the tongue weight is WAY too light, in which case I can see it. Note tongue weight should be about 13% of fully loaded TT ACTUAL fully loaded weight.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 4 Canada Provinces, & 2 Territories.
LoudRam
New Jersey
Posted: 04/23/08 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
I didn't realize that they had those kits. That spare kit is a must have. I think I'm going to order two. Thanks for info.
Todd
Desert Storm Vet (US Navy)
2002 Fleetwood Prowler Lynx 30'
2001 Dodge Ram 1500 Quad Cab 4X4 w/360 (not stock)
Predator DX2 brake controller
Equalizer Sway Control Hitch
If you can read this thank a teacher
If you can read this in english thank a vet
pdvandusen
Snow Hill, NC USA
Posted: 04/23/08 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
They have a double spare kit. I got mine a month or so ago.
Doug & Mary Ann Van Dusen and Phoebe (the dog)
2008 Chevy 1500 Silverado 5.3L LTZ 3.73, HD Trailer Pkg.
2008 Jay Feather LGT 31E
Equal-i-zer, Prodigy BC and TomTom GPS
LoudRam
New Jersey
Posted: 04/23/08 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
Even better
RustySocket
SW Washington
Posted: 04/23/08 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
Someone installed the pin wrong and your hitch isn't torqued properly if the bar was flopping around.... if your truly talking about a equalizer brand hitch..... or are you talking about a generic wd hitch?
can you post a picture of the bent L pin?
2manytoyz
Central FL
Posted: 04/23/08 10:28pm Link  |  Quote  |  Print  |  Notify Moderator
Are you sure your L-brackets aren't too far back? The only time I've heard of this happening is when these brackets are beyond the 32" mark. They end up being pulled out from under the pin.
Because of the location of my propane tanks, I had to move my L-brackets forward of the optimal 32" mark. Still work well, but no fear of spring bars pulling out from under the L-pin.
Even if my pins were bent, no way for the bar to hop off my L-bracket. The L-pin would have to shear before the bar could lift off the L-bracket. It's really well captured.
Robert
Cocoa, FL
2007 Rockwood TT 2502
Equalizer Hitch
Prodigy Brake Controller
2005 Nissan Xterra
2006 Jeep Wrangler Unlimited
Yamaha EF2400iS
Earl E
Klamath Falls, Oregon
Posted: 04/23/08 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds to me like something may be out of adjustment. Mine have so much pressure on the L brackets I don't see how they would even come loose.
2008 Keystone Springdale 252
2004 Chevy Silverado, 5.3 L V8
Prodigy brake control and Equal-i-zer
Retired and traveling all we can!
Bucky Badger
Madison, WI
Posted: 04/24/08 05:28am Link  |  Quote  |  Print  |  Notify Moderator
LoudRam wrote:
Even better
LOL I picked mine up yesterday...A must have
2007 Nissan Titan, 5.6L Big tow, Equli-z-er Hitch
www.titantalk.com
2007 Forest River Salem 27RB LE
Nights camping 08 (15)
Rallies/Gatherings
IL
WI
lat471
Lebanon, PA
Posted: 04/24/08 05:54am Link  |  Quote  |  Print  |  Notify Moderator
After going to a Ace hardware and getting extra clips and pins I saw the spare kit and ordered it for the rest. It sounds like there wasn't enough weight on the bar for it to come loose while traveling. Make sure your L bracket did move back.
07 Cameo LXI F35FD3
R Taj-We-Haul
