bngntn
Estill Springs, TN
Anybody ever fell (or almost) down your steps? Have you noticed that the tread on the steps are small? The steps at my house have a tread of 10 inches whereas on my fiver the tread is 8 inches. If you have a size 10 or greater shoe, you will notice that your foot tends to "roll" down the step with the narrower tread. Is there a replacement foldaway step that has a larger tread?
B & G & Pups
Major USAF (Ret)
2008 Chevy 2500HD D/A Crew Cab
2007 Cruiser F/W
"Happiness is not a station you arrive at, but a manner of traveling."
Kanyonkitty
Gerrardstown, WV
I had the same problem as you, plus the fact that my step did not "extend" out away from the trailer enough when I opened it. This is how I solved my problem: I bought a set of "SPA" steps, light weight, waterproof and much better tread size.
2005 F350 PSD, 4x4, Lariat Crewcab, FX4, Camper pkg, Line-X 2006 Sunline T-2499 custom ordered with 24 options incl. aluminum roof & Onan CampPower 3600 LP Genny, Proud member of: Sunlineclub.com Single? check out MSN Groups Open Roads Singles,
GACampnGirl
Georgia
Yes, I have fallen down my steps(womens size 9 shoe.) I have even fallen "up" my steps (although in my defense, I was trying to manuever around my daughter who decided to STOP in her tracks). Luckily, we have a MH with a small ground clearance or my injuries would be worse
Those steps are looking pretty good right now though
Spread the word about Campground Etiquette!
CAMPING ETIQUETTE CHECKLIST
SteveB
Rhode Island
Yes, right off the top step. Usually in a rush when the steps are wet. The carpet covers help a little but rushing and inattention are the biggest culprits.
SteveB
'01 Dodge Ram 3500 CTD HO 6sp, Reese 15K Pro w/ Kwik Slide, Prodigy
'04 Jayco Jayflight 28.5RKS
Dustytuu
Colorado USA
Know someone that fell out the door and broke his leg, this year. Still recovering.
A lady we know also fell on the steps and broke both of her ankles, last year. She has recovered now
2008 dodge 5500, diesel, bedsaver, pressure pro tire.
2008 Carri-Lite 36SBQ, 4 slides,dishwasher,washer/dryer,2 fireplaces
D & D
Two Schnauzers, & cat
http://s6.photobucket.com/albums/y250/Dustytuu/
Criminals prefer unarmed victims!
5th4me
calif
Yes,and never spilled a drop...
Billyayle
Chandler Arizona
The DW took a good fall off of the top step. I picked up some fullwidth Anti-Skid strips at Lowe's. They cover the full step and have a yellow reflective stripe on them. Makes for a nice reflector when the steps are down.
But I do agree, most fold down steps are very shallow. I like the ones pictured.
2005 Dodge 3500 Crew Cab 4x4 LB SRW PacBrake
2008 Cougar 310SRX 5th
YZ400 with tweaks :-)
Kaw. 220 quad
jeaelectric
knoxville
i fell but it may have been because the welds on the steps broke.
I said forget it and bought a new fiver.
2004 PS Ford F-350 DRW
2007 S.B. Bristol Bay 3420BH
C.B.
APPLETON WI USA
bngntn wrote: Anybody ever fell (or almost) down your steps? Have you noticed that the tread on the steps are small? The steps at my house have a tread of 10 inches whereas on my fiver the tread is 8 inches. If you have a size 10 or greater shoe, you will notice that your foot tends to "roll" down the step with the narrower tread. Is there a replacement foldaway step that has a larger tread?
I replaced my original 3 step 9"rise with a 4 step 7" rise . Still only 8" tread but much easier going up and down.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
TORQSHIFT AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE
PRODIGY BRAKE CONTROLLER~C-BETR MIRRORS~ROTOCHOKS
CB Family Fleet
Butch&Barb 03Cardinal~Duane&Holli 05CedarCreek~Kris&Katy 06Cherokee~ Brian&Maia 04Jayco
moonlighter
Baton Rouge, LA
Check to see if the step unit can be moved out away from the I-beam attachment. Mine was attached to the I-beam but could be moved out with wood block spacers about 2". Was able to use some of the other mounting holes in the step frame, without drilling new ones. This gave more room on the top step for firmer footing. I guess it was easier for them to mount it directly to the frame.
Floyd & Betty (in the deep south)
1998 Dodge 24 valve(and you can hear every one of them)diesel, 2000 Cedar Creek 30RLFS fifth wheel
