Lar_2287
Dale City, VA
My Moho's rear axle starting leaking and I need a Seal/Gasket. My question, is workhorse part of GM ? If so I can try to get one at the chevy dealer, if not then I have go further away from home to purchase a seal. Luckily my neighbor is a retired mech, and he will do the installation.
Larry
Itasca Suncruiser, 33V
1 Wife, 2 Married Daughters and 4 Grandsons
Trailblazer
GMC PU
Rocket_Heart
Waterville, Ohio
Work Horse makes the chassis only. They install the GM engines and Allison transmissions. I'd call Work Horse first then go from there.
Thomas "Rocket Heart" Emahiser
Anna,DW
Matthew
Alaina
2007 Itasca Suncruiser 35L
8.1 Vortec - 6 speed Allison Trans.
Workhorse W24 Chassis
2001 PT Cruiser (Toad)
Waterville, Ohio
"Go Bucks"
ArchHoagland
Clovis, CA, USA
A list of Workhorse dealers in VA is found here
My local Chevy dealer is also a Workhorse dealer and they just did my driver side rear seal a couple months ago.
It takes a few trips for all the old oil to clear out of the wheel after the new seal is installed.
2004 Monaco
La Palma 36DBD
Two Slides
2 Potties
Workhorse 22 chassis
8.1 gas engine & Allison transmission
6.9 MPG based on a 6,000 mile trip around the U.S.
US Gear Toad Brakes
dunerdb
San Deigo, Ca
My mechanic indicated that you need to start with Workhorse and proceed from there. You may or may not be able to use a GM part to fix a problem with a Workhorse chassis. Your problem sounds like a GM seal should fix it. But engine parts are different such as the water pump, you must get a Workhorse water pump.
Dick
99 HR 33', Banks,Davis Tru Trac,bilsteins
BroncoRVer
8,600 feet elevation, Colorado
Workhorse replaced my passenger's rear seal last year....not with a replacement OEM seal, but with a bead of silicone...said it was better than the Workhorse seal.
2006 Winnebago Voyage 35A, W-22
Brake Buddy, Aventa II tow bar, Protect-A-Tow
2005 Hyundai Elantra toad
wny_pat
Western NYS
Probably American Axle and you probably can get the seal/gasket from either a Chevy Truck Garage or Workhorse or NAPA.
dapark
SLC, UT
It would be a Dana rearend. Do you know what model you have?
Manufacturer–Model Ring Gear(Inches) Fld Cap(Pints/Liters) Ratio
American Axle 10 ½ 10.5 7.2/3.4 4.63
Dana 80 11 8.2/4 4.63
American Axle 11 ½ 11.5 7.3/3.6 4.63
Dana M80 (W16 w/6.0L) 11.5 8.1/3.9 5.13
Dana M80 (W18 w/6.0L) 11.5 8.1/3.9 5.38
Dana M80 (W16 & W18 w/8.1L) 11.5 8.1/3.9 4.63
Dana S110 11.8 16/6.6 4.88
Dana S110 (Allison Six Speed) 11.8 16/6.6 5.13
Dana S135/150 (19.5” tires) 14 24.5/11.6 4.78
Dana S135/150 (Allison Six Speed w/19.5” tires) 14 24.5/11.6 5.13
Dana S135/150 (22.5” tires) 14 24.5/11.6 5.38
Dana S135/150 (Allison Six Speed w/22.5” tires) 14 24.5/11.6 5.86*
Dana S130 12.2 16/6.6 5.13
Dana S130 12.2 16/6.6 5.86
2005 Allegro Bay 37DB WH22
1999 Durango is the Toad or
the Milan or the ATVs. Depends on
our compass heading.
Wherever I happen to park
Workhorse uses some GM parts, and some parts from other folks.. Give them a call and they can tell you where to get the part. Have your VIN handy
I sometimes tell the story of 3 calls to customer service, 3 different companies
Hughes: Call to India.. 7 hours, no joy,
Xantrex: Washington State, 15 minutes, great joy
Workhorse: Call to Troy Michigan, 1 minute, Joy
Kind of hard to beat that kind of service
(I do admit my quesiton was #1 on the FAQ list)
wny_pat
Western NYS
If you want bearings, I know where to find them! One phone call!
scbullis
Travis AFB CA
Without the Workhorse model number, its hard to tell for sure, but looking at the Workhorse chassis guide, it appears most of the W-series chasis use Dana S135/150 rear axles.
