RV.Net Open Roads Forum: Need inputs on leveling 5er when attached to TV...
Search only in Towing
Open Roads Forum  >  Towing
 > Need inputs on leveling 5er when attached to TV...
crusmsl
Farnham, VA. USA
Posted: 04/24/08 10:40am Link  |  Print  |  Notify Moderator
Note: I also posted this thread in Fifth Wheels forum but just wanted to see if I get additional comments here.
OK, after blowing a rear tire on both sides, I'm thinking maybe the 5er is putting too much weight on the back axle. When hooked to your TV, should the 5th wheel be completely level?
I talked to the dealer where I purchased my rig. They also installed my hitch & leveled the unit. The service manager told me that they can't get a 5th wheel completely level when hooked up and that it's better to have a little rise in the front of the 5er so that TV handling isn't adversely affected.
Is this information correct or do I throw the BS flag?
Thanks for any inputs.
Money2Burn
Colorado
Posted: 04/24/08 11:00am Link  |  Print  |  Notify Moderator
How much of a rise is there ? I was always told that it should be level, even if it means flipping the axles and then raising the hitch to level it.
Regards, Money2Burn
2004 GMC Sierra 2500HD Duramax
2004 Keystone Challenger
I share my wisdom with those who seek it !
Road Runners
Tampa Bay, Florida
Posted: 04/24/08 11:09am Link  |  Print  |  Notify Moderator
I just checked the Dexter axle web site. Here is tip number 11 on the proper running of your axles.
Tip #11: It is very important to pull your trailer so that it is running level. If the hitch is too high or too low, the trailer axle(s) may be unevenly loaded and can result in premature tire or axle failure.
Here is the address of this tip page - http://www.dexteraxle.com/running_gear_tips
'05' F-250 Power Stroke
'00' 30' Cameo Fifth Wheel
George H
Washington
Posted: 04/24/08 11:39am Link  |  Print  |  Notify Moderator
Many newer units are setup with height adjustments at the spring mounts, IMO a preferred option to axle flip (more moderate rise, not as much of an impact on entry height).
George, Juanita and Mandie (boss Shar-Pei)
01 F350, PSD, DRW
05 Carri-Lite 32RS3
Leeblev
Pinole, CA
Posted: 04/24/08 12:00pm Link  |  Print  |  Notify Moderator
Add to the above posts: You can also adjust the kingpin housing up or down, depending on the need. If you blew tires on the rear axle, that could be a sure sign that you are overloaded on it and the front end needs to come down.
I echo the above in that the 5er needs to ride level for weight distribution.
Lee
2001 36' Kountry Star DP
outdoorsman2007
Somewhere in the US
Posted: 04/24/08 12:24pm Link  |  Print  |  Notify Moderator
The fifth wheel should ride level. As for blowing tires on the rear of your tow vehicle, have you weighed your rig? What size (load range) tires to you have on the tow vehicle?
KID2TEXAS
Memphis, Tenn
Posted: 04/24/08 12:47pm Link  |  Print  |  Notify Moderator
ok was it the truck that blew the tires or the 5R that blew the tires?? if its the truck then maybe you have to much weight for the type of tires you have on it. Its not an HD so you may not have load E tires on the truck.
Big difference in the fix if its the truck that is blowing the tires.
Kid
2006 Ford F-250 Super Duty, Amarillo Special Edition 4 X 4 & 6.0 PSD,
Tow Haul/Tow Boss/Tow Command, 18" load E tires standard.
Me, a Wife and two crazy kids
2006 Holiday Rambler, Next Level 38FKS
BarneyS
S.E. Lower Michigan
Posted: 04/24/08 01:03pm Link  |  Print  |  Notify Moderator
Please do not double post. See the replies to your question here.
Barney
