RV.Net Open Roads Forum: Beginning RVing: Water Pump problem
 > Water Pump problem
Kentucky Steve
Crestwood, Ky
Posted: 04/24/08 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
I have a new TT. the water pump was working, I filled the water tank up and ran water throught the system to clean out the anti freeze. I then hooked up the city water, and ran more water through the system. OK so far.
When i refilled the water tank back up to run the bleach out, the water pump just runs constantly, but no water is pumped. Someone told me to unhook the hose on the outlet side to re prime. Does this sound right, and what is the outlet side?
Thanks in advance!
Chuck&Gail
In the Colorado Mountains
Posted: 04/24/08 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
Did you empty water heater tank? If so, it takes at least 6 gallons to fill.
Did you open both hot and cold faucets with pump running? Did it spit at all?
Did you check your pump intake isn't set to draw antifreeze from a bottle (if you have that option).
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
tandkj
Full timer
Posted: 04/24/08 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
If you have the city water connected to a hose and the hose on the pump will run but the water is taken through the hose and city water connection. Also, the valve has to be in the correct position to pump water from the water pump.
08 Camelot
07 Ranger Toad
One lost Golden Retriever
Jerrybo66
AZ
Posted: 04/25/08 11:44am Link  |  Quote  |  Print  |  Notify Moderator
If your unit is new it's possible the pump picked a piece of plastic not cleaned out when they cut the holes in the tank. When I had that problem, taking the pump apart and cleaning out the little piece fixed it.....
Support the Country you live in or live in the Country you support
2003 Sierra SP 26'Toy Hauler
1997 F-350, PSD, 4X4, red Crew Cab, long bed.
2007 Arctic Cat Prowler, Arctic Cat 500
K3WE
Missouri
Posted: 04/25/08 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
My pump is hard to prime sometimes too- it gets an air block in it and like you say- runs, but dosn't pump....
I don't have the procedure figured out EXACTLY, but running some water through the hose connection (and turning it on and off a time or two), and opening lots of faucets seems to clear the air and get the pump kicked in....
Hornet28BHDS
Parker, PA
Posted: 04/25/08 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
I ahd this problem when dewinterizing. Unscrew the pipe from the tank and then re attach it. Then it will work.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
Wxguru
Austin,AR
Posted: 04/25/08 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
so you have to turn off the valve to the water pump to use the city water connection?
1999 Keystone Cougar Ultra-Lite 261E
2003 Dodge Ram Quad Cab 5.7L HEMI
K3WE
Missouri
Posted: 04/25/08 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
I suspect Tand has one of those winterizer kits where you can turn a valve, and suck anti-freeze directly from a jug...
But I suspect the original poster has a simple "vapor lock".
kennyzzz
buffalo new york
Posted: 04/26/08 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
mine was running like crazy,i forget to push down the low point drains.
Chevy 2008 1500 X-cab 5.3 373 posi 4x4 z-71
2003 jayco quest 190 4059 lbs.
