RV.Net Open Roads Forum: The 454 is out of the MH
 > The 454 is out of the MH
Page of 10
Seanman
Arroyo Grande, California
Posted: 04/25/08 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
Love to see this stuff! Did this a couple a years ago on a P-30 winny....but I went though the front. Good time to rebuild the trans with a new TC. So many thoughts but so little time. Just took mine in for smog. In getting it ready I found the ported vacuum switch for the heat riser went bad and the same for the air cleaner hot/cold air intake......both can be deadly for a 454. Good luck with it and keep us posted on your endeavor.
87 Holidy Rambler Imperial
P30,454,TH400,Gear Vendor,Thorleys
FMCA F381797
74discoverer25
indiana
Posted: 04/25/08 11:16pm Link  |  Quote  |  Print  |  Notify Moderator
i am going for rebuild soon, i think im gonna spend a little extra and stroke it, make ie a 488 or 496, supposed to be great for torque, that is what 8.1s are, you might have your engine guy give you a price.
i am lucky, mine comes out of front.
steve t.
74 discoverer 25'
p-30 454
sydney the half blue heeler
Pokiii
Denver Colorado
Posted: 04/25/08 11:51pm Link  |  Quote  |  Print  |  Notify Moderator
Ben,
I don't have any good suggestions to offer, I just want to say I envy your ambition and courage, keep us posted on your progress.
Best,
Pokiii
sum1
So-Cal
Posted: 04/26/08 12:26am Link  |  Quote  |  Print  |  Notify Moderator
Please let us know what he finds in the engine.
Bronco4me
Ridgecrest, CA
Posted: 04/26/08 12:46am Link  |  Quote  |  Print  |  Notify Moderator
Good luck! My '92 HR is a P-30 also, but says that engine removal is through the driver door (yes, after the seat and steering column is removed...).
Bronco
1992 Holiday Rambler Aluma-Lite 33CSXS
2005 Yukon Denali
1990 Bronco XLT Fishin' wagon
MN Ben
Minnesota
Posted: 04/26/08 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
John&Joey wrote:
Who's doing your rebuild here in MN. If you don't want to post, PM me. Thanks.
Jeff has a machine shop in the back of CarQuest Auto parts in Hutchinson MN. There is a cam & crank shop in Winstead.
Ben
Daveinet
il
Posted: 04/26/08 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
Such a familiar site. Tooooooo familiar. Congrats on getting it out. I'm on my second trip. Don't have the everything tweaked yet.
Make absolutely sure that you have a roller cam put in it. Todays oils do not contain as much zinc because it is believed that the zinc ruins the catalytic converter. The cam needs the zinc. If you do not ad zinc - at least during break in, you can count on one hand the number of the number of months before you loose the cam. But the best solution is the roller cam if it didn't have one to begin with.
Dave
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Thorley's & Magnaflows,
Howell/Edelbrock MPFI, Koni FSD,
Class A built for gear heads
My Revcon Website
Revconeers Forum
XP activation frustration
Cousin_Eddy
Peoria, AZ
Posted: 04/26/08 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
MN Ben,
I am very curious as to what happened to the piston and what the cause was. Please update us if you find out.
Thanks!
1995 33' Southwind Fleetwood Model LW
Jim83Itasca
La Quinta Calif
Posted: 04/26/08 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
A bottle of E.O.S dumped in on the initial start (2000-2500 RPMs) for 30+ minutes will allow that cam the proper breakin it deserves, In fact you can obtain a few bottles and with every oil change just put in a 1/4 bottle.....
Jim
huskyhauler
AZ, Maybe..
Posted: 04/29/08 04:03am Link  |  Quote  |  Print  |  Notify Moderator
Makes me like my Deere-Oshkosh even more. Drops out through the bottom.
Better than alot of some of the old P-30's. My first p-30/454 job required the front clip to be completely removed. We tried getting out from the bottom with the tranny,to wide. No way out the top, as the doughouse opening was to small. Nothing beats calling a glass shop out so you can pull a engine.
Your Deere-Oshkosh Specialist
It's A Marine not reporters
Who has given you freedom of the press
It's Marines not profesors
Who gave you freedom of speech
It's Marines who salutes the flag
serves beneath the flag
& whose coffins draped by the flag.
Page of 10
