RV.Net Open Roads Forum: Travel Trailers: Sewer hose carrier - enclosed underbelly
 > Sewer hose carrier - enclosed underbelly
drfife
Dallas, Texas, USA
Posted: 04/25/08 11:33pm Link  |  Quote  |  Print  |  Notify Moderator
jeanspach wrote:
Do you have a picture? Sounds like a good idea.
Here's some pictures of my sewer hose carrier. I used Igloo cooler hinges and strapped it to the rear frame using long stainless steel hose clamps :
Russell
'02 Chevy Suburban 2500 4X4 8.1 4.10 : '03 SunnyBrook Titan 29DBS
'04 BrakeSmart Controller : '01 Hensley Arrow Hitch
La_Bolt_Fan
Los Angeles, CA
Posted: 04/25/08 11:40pm Link  |  Quote  |  Print  |  Notify Moderator
Forgive my ignorance, but why not store it in the bumper??
Backpacking one week, RV'ing the next!
LarryJM
NoVa
Posted: 04/26/08 03:35am Link  |  Quote  |  Print  |  Notify Moderator
browns329 wrote:
I was skeptical about whether I needed a carrier, since several people on the forum say they still carry it in the bumper. But, even with my brand new TT bumper, and only driving about 45 minutes, my nice new Valterra EZ Coupler hose has gotten scratched up a little bit at the connectors. I think the plastic fence post option looks pretty good.
Yes, I know I can do a search and get lots of info on sewer hose carriers, but I was looking for tips on mounting one on my trailer that has an enlosed underbelly. The only exposed frame under the trailer is at the very outside edges, unless I put the bolts through the skin under the TT. Has anyone mounted one just above or just below the rear bumper?
My TT doesn't have a bumper and it has an enclosed underbelly so I found the first place to the rear of the axles where two bolts holding up the underbelly were directly across from each other and used a piece of flat iron to secure a mount using those bolts and then attached some angle iron with long bolts to secure my fence post hose carrier to it. Below are two pics that show my mount.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974. TRAILER MODS
Bumpyroad
Virginia
Posted: 04/26/08 05:09am Link  |  Quote  |  Print  |  Notify Moderator
back when I was using a stinky slink, I slid a section of plastic gutter into my bumper to make sliding it in easier. Of course I would recommend you do yourself a big favor and get either a sewer solution or macerator pump.
bumpy
browns329
New Jersey
Posted: 04/26/08 07:23am Link  |  Quote  |  Print  |  Notify Moderator
Nice! Where did you get the Igloo hinges? Off of an old cooler, or were you able to buy them? Want is the metal eye hook on top of the carrier for (1st pic)?
2003 GMC Yukon XL 2500 (3/4 ton), SLT, 4x4, 8.1L, Autoride, 4.10 gears
Putnam XDR, Equalizer 1400#, Tekonsha P3
2008 Jayco Eagle 314BHDS (Bunk house double slide)
Me, DW, 2 DD, lots of pets
txtaco
Richmond, Texas
Posted: 04/26/08 07:36am Link  |  Quote  |  Print  |  Notify Moderator
Here is a place to get the hinges...
Igloo Hinges
I like that idea also, I am going to try and build one this weekend.
2004 GMC 2500HD CC 6.0/4.10 4x4
2008 Jayco G2 32BHDS
drfife
Dallas, Texas, USA
Posted: 04/26/08 08:26am Link  |  Quote  |  Print  |  Notify Moderator
browns329 wrote:
...Where did you get the Igloo hinges? Off of an old cooler, or were you able to buy them? Want is the metal eye hook on top of the carrier for (1st pic)?...
I bought the Igloo Surelock 95 Hinges (1 pair) model #9790 at my local Academy Sports store several years ago for $3.99.
The metal eye hook is used to keep the cover closed while in transit.
browns329
New Jersey
Posted: 04/26/08 08:33am Link  |  Quote  |  Print  |  Notify Moderator
So the hook just slides through a hole in the post sleeve and the cover to keep it closed?
drfife
Dallas, Texas, USA
Posted: 04/26/08 09:39am Link  |  Quote  |  Print  |  Notify Moderator
I screw it in.
I drilled a small pilot hole and then threaded the eyelet screw in the hole.
I made this set-up 5 years ago and it still works great.
Loopy
Western Pennsylvania
Posted: 04/26/08 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
Picture of my storage.
All thread with a 6" mending plate to hold it. Just drill two small holes on the outer edge of the frame and it works great.
Bryan , Jess, and our Parsons Russell Terrier, Melvin
1999 Chevrolet Tahoe 4D 4WD 5.7L 3.73" Rear End
Reese Strait-Line Dual Cam Weight Distribution Hitch
Tekonsha P3 Brake Controller
2008 Jayco Jay Flight G2 20BH and Mods
