RV.Net Open Roads Forum: Fifth-Wheels: grease on top of hitch
 > grease on top of hitch
Rmcgrath53
Howell
Posted: 04/26/08 06:55pm Link  |  Print  |  Notify Moderator
Maybe some one may be able to help me. I brought my trailer home and the demo guy just told me to maintain the fifth wheel hitch by greasing the grease fitting. The manual says to grease the top of the hitch if you have no grease plate on the pin. My question is do I grease the top of the hitch? I have the trail air pin box.
Thanks
Ron
2008 keystone Everest 345s re
2002 F350 4x4 7.3 diesel crew cab dually. 135,000 miles extra leafs.
Banks stinger/ with an edge attitude set at tow
prodigy 3p curt 20k hitch
trail air suspension trail air pinbox
2 e2000 honda w parralel kit
jefff929
Pacific wonderland, wet side
Posted: 04/26/08 07:02pm Link  |  Print  |  Notify Moderator
use that messy crud if you must.
We bought a lube plate from CW and would never grease the hitch or area around the king pin.
2001 Dodge 2500 QC, Diesel, Auto, 4x4 Shortbox, Stull running boards, 26.5' Sundance 5er
My Baby
Another NWBomber
portablevcb
Tijeras, NM
Posted: 04/26/08 07:06pm Link  |  Print  |  Notify Moderator
We have that too. Soooo much nicer than grease.
2009 Dodge 2500 Double Cab Cummins
2003 Skyline Nomad 24ft Fiver
Me and Wife
Maggie the Old English Sheepdog
Road Runners
Tampa Bay, Florida
Posted: 04/26/08 08:33pm Link  |  Print  |  Notify Moderator
Get yourself a teflon plate that fits around the king pin hitch. It is called a lub plate, but it is just a special cut piece of teflon. It works better than grease with no mess.
'05' F-250 Power Stroke
'00' 30' Cameo Fifth Wheel
SkiDood
Peoples Republic of Minnesota
Posted: 04/26/08 09:05pm Link  |  Print  |  Notify Moderator
Lube plate, for the win.
Late model wife
2002 Daughter
2005 Daughter
2007 Ram 3500srw 5.9L Cummins Laramie. QC Short bed.
2008 Crossroads Zinger 30RB 5th wheel.
18k Reese signature series slide hitch
Glen41
North Texas
Posted: 04/26/08 09:28pm Link  |  Print  |  Notify Moderator
Yep, another vote for lube plate. But I put a little grease on the kingpin itself where the hitch locks to it. That is the part that actually pulls and slows the trailer. The top plate just holds up weight of the trailer at the pin box. Both are involved in turning a corner. So far they haven't developed a teflon sleeve for that.
Just for my info, where did someone find Teflon Lube plates? The one I got at CW was just polypropolene. I'll use it till it wears out, but Teflon is slicker.
Doing my part to keep America's highways cluttered up.
2006 Chevy 3500 D/A DRW Prodigy, AirBags, 34 ft Travel Supreme
http://smartsforsale.blogspot.com
robbins
Soulsbyville, Ca
Posted: 04/26/08 09:32pm Link  |  Print  |  Notify Moderator
Lube plate for me too.
No greasy mess for me!
See 'ya on top
Keith
2004 2500HD silverado 4x2 extra-cab
265/75/16 Hercules tires
Reese 15000 Pro Hitch
2006 Gulf Stream 30FBRG
smkettner
Posted: 04/26/08 10:38pm Link  |  Print  |  Notify Moderator
Lube Plate at CW
YnotTurbo
Waldorf Maryland
Posted: 04/27/08 05:06am Link  |  Print  |  Notify Moderator
Lube plate...I only put a little bit of grease on pivot points on my hitch.
Navy Chief (Ret.) but still working...
2011 Dodge Ram 3500 Laramie w/6.7 CTD.
2011 Mobile Suites Lexington 43
http://i176.photobucket.com/albums/w200/YnotTurbo/Newsetup.jpg
Roy T
Dodge City, Kansas
Posted: 04/27/08 08:31am Link  |  Print  |  Notify Moderator
Teflon plate is a lot cleaner. They only cost around $10. They also don't collect dirt and make a mess.
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
