hit_escape
Helena, MT
I figured out what is causing the leak in my shower. The leak was right below the tub. There appears to be a crack in the PVC P trap. The problem is that the access vent is only about 6" by 8". The area around the pipe is even smaller. I guess it would be necessary to remove the tub to get to it. I don't want to do it myself and I'm pretty sure a repair shop would need about $500 to do it.
Here's my question: what are my options to reinforce the PVC pipe without cutting it or removing the tub? Can I paint the cracks with some glue and stop the slow leak? What glue should be used? Should I use plumber's tape? Thanks in advance.
,Bill
Lovely wife of 25 years.
2003 Explorer XLT 4.6 V8 Advancetrac Class III/IV hitch, OEM Tow Package, 3.73 rear end, 5,200 lbs loaded
EU3000 Generator
Equal-i-zer
Voyager Brake Controller
2003 26' Trail-Lite 8263s Slide Out, 3,900 lbs dry weight.
big dave
Soldotna, Alaska, USA
You might try some of that epoxy putty they advertise on TV. I've used epoxy and glass mat with success (doesn't look good, put does work).
Water froze in the trap?
Dave & Rose C
90 Safari Ivory 34' DP
04 Saturn VUE V6
tvman44
Southwest Louisiana
What about eternabond, they say that stuff sticks to every thing forever.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
DavesWife
Homer Glen, Illinois
big dave wrote: You might try some of that epoxy putty they advertise on TV. I've used epoxy and glass mat with success (doesn't look good, put does work).
Why not give it a try....My 7 year old always says "Mom, you need that stuff" whenever the commercial is on...
And then let us know if it doesn't work.
Keystone Sprinter 311BHS
2007 Silverado 2500HD 4x4 4.10
smkettner
Southern CA
JBweld
Todd Barney
Atlanta area, GA, USA
How about this stuff? Seems like a handy thing to have around an RV, anyway.
2006 Maxlite 30BHS
Maxlite Photos
Large: 2003 Dodge Ram 2500 Quadcab 4x4 V-10 5spd manual 3.73
Equal-i-zer, Prodigy
Medium: '03 MPV ES
Small: '91 Miata
Pad the walls, we got 8-yr-old twins in here!
Road Runners
Tampa Bay, Florida
If you can get your hands into the area of the crack, that two part epoxy putty will solve your problem. Home Depot sells that expoxy stick in the plumbing department. It is called Plumber's Epoxy or something like that. I repaired a crack in the flushing water bowl of a toilet four years ago with that stuff and it is still holding. I have also repaired the plastic fender on my camper and it worked like a champ. That stuff really works!
'05' F-250 Power Stroke
'00' 30' Cameo Fifth Wheel
handye9
Park City, IL 60085
Try "Plumbers Goop". Available at Home Depot. The trap must be dry inside and out when you apply it. I've seen it work on a cracked toilet tank.
06 Titan Kingcab
06 Flagstaff 831QBSS
Wife and I
Buddy the Beagle
USN MCPO (E9) Retired (22 years of service)
Check out my mods
K&R
Oklahoma
handye9 wrote: Try "Plumbers Goop". Available at Home Depot. The trap must be dry inside and out when you apply it. I've seen it work on a cracked toilet tank.
I second this stuff. Have used it several times always with success
bldrbuck
colorado
I bought some Rescue tape at an RV show. If you can wrap it around the cracked pipe it will do the job. If not I'd try one of the Goop products or Shoe Goo.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
