RV.Net Open Roads Forum: Travel Trailers: Repair PVC Drain without replacing?
 > Repair PVC Drain without replacing?
Economical Handyman
S. California
Posted: 04/26/08 10:24pm Link  |  Quote  |  Print  |  Notify Moderator
Todd Barney wrote:
How about this stuff? Seems like a handy thing to have around an RV, anyway.
It the surface is clean & dry, pull it tight as possible when wrapping. Wrap one direction on the pipe, then wrap over the first layer the other direction. Should solve your problem.
DeWayne & Judy
04 3810 Dutch Star
ISL 370
Frank's autoformer
01 Sahara Jeep-toad
F 374382
It is hard to kiss the lips at night, that has chewed your butt all day long!
Jpaul4
Posted: 04/27/08 09:47am Link  |  Quote  |  Print  |  Notify Moderator
You can find the silicone tape in a lot of places. If you can get at it to use that it would be the easiest. You would only need to wrap it one way. Just overlap your seems a little. It's supposed to handle up to 700lbs psi. So I would think it would work great on a drain.
Kajtek1
CA
Posted: 04/27/08 09:59am Link  |  Quote  |  Print  |  Notify Moderator
I used the black tape pictured above, or it siblings and it doesn't work well on plumbing. The tape is great as a self-fusing rubber if you need electrical insulation, or shock absorbing pad, but it doesn't stick to the pipes and water comes out from under it.
Goop is good, epoxy would be better if you know how to use it. Can turn really mess if you don't.
Pessimist sees dark tunnel, optimist sees a light at the end, realist sees lights of coming train.Engineer sees 3 idiots on the tracks.
JUrban
Delaware
Posted: 04/27/08 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
I second the JB Weld. to get a good bond make sure it's dry and sand it a bit to get a grip. Will last longer than the RV
John
2008 Tiffin Allegro Bus 40' QSP
2006 Chevrolet Colorado Toad
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Copilot Live Laptop 10 GPS
hit_escape
Helena, MT
Posted: 05/05/08 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
Last Update:
Thanks for all the suggestions.
It turned out that the leak was at the drain flange where it meets the tub floor. It finally got warm enough to not worry about freezing, so I put the drain plug in and dumped a gallon of water in the tub. I reached up in the tiny front access and water was coming in with the tub plugged. I dried it out and put a bead of silicon stuff on the flange and let it dry. That stopped the leak so I think the problem is solved. There is not much room to get a wrench in there, so I think I'll get by with a bead of silicon for now. I canceled the repair appointment so no hit to the checkbook. Thanks again all.
,Bill
Lovely wife of 25 years.
2003 Explorer XLT 4.6 V8 Advancetrac Class III/IV hitch, OEM Tow Package, 3.73 rear end, 5,200 lbs loaded
EU3000 Generator
Equal-i-zer
Voyager Brake Controller
2003 26' Trail-Lite 8263s Slide Out, 3,900 lbs dry weight.
