Mainecoon
Meadville, PA 16335
If you are on a public sewer system and want to dump into their system I would check with them. Many will tell you can not dump into their system because you have chemicals in your system. The reason I know this is because I am on the board of our local sewer authority.
mrblaine
SoCal
Mainecoon wrote: If you are on a public sewer system and want to dump into their system I would check with them. Many will tell you can not dump into their system because you have chemicals in your system. The reason I know this is because I am on the board of our local sewer authority.
Where do all the places that let you dump your tanks send their collections of stuff?
05 Dodge 3500 4x4 DRW Long Bed 4dr
07 Lance 992
III so far.
TennesseeBob
NW Tennessee
When I visit my sister in New Hampshire I go to the town sewage plant to dump
2001 Dodge 2500 V10
2004 Newmar American Star 32RLKS
Paris,TN
dakonthemountain
Crestline, California
The Crestline Sanitation District, up in the mountains where I live states that it is against the rules and regulations and has been for a long time, to dump in clean out or any other sewer system attached to your house because of the chemicals used in your tank. They recommend a special dump place that charges $5 per dump... I have never been there.
Dak
Dak's 77 rig: 1977 F250 Ranger w/ 1977 Lance #700 11.6 cabover
They are loaded with the bells and whistles. and almost completely restored
to original!
Pictures of the truck and camper are here
Escapee #22435
Reddog1
El Dorado, CA (above the fog & below the snow)
Boy, I feel overwhelmed. I am not sure if I can ever poop again. I am not sure if it is because the rules are so different, depending where you live, or so much misinformation. Probably a bit of both.
I will not challenge any specific post, but would advise an unknowing reader to take this thread as entertainment only, and check where you live to see what you can or cannot do.
Personally, I have lived the past 35-years on well water and a septic system. I have had this experience in no less than two counties, and and three sewer districts. I am truly amazed at some of the stuff I read here. I think I will go and mix a margarita.
whazoo, you and trails2004 are welcome to join me. It would probably be more healthy than some of the info we get.
Wayne
stevenal
Newport, OR, USA
dakonthemountain wrote: The Crestline Sanitation District, up in the mountains where I live states that it is against the rules and regulations and has been for a long time, to dump in clean out or any other sewer system attached to your house because of the chemicals used in your tank. They recommend a special dump place that charges $5 per dump... I have never been there.
Dak
Sounds like money is the issue. Sewer rates are generally tied to the water meter reading. An RV is likely dumping water that has not gone through a local water meter.
Formaldahyde is a problem, but black tank products containing it are hard to find any more. All the bleach that goes down a typical drain is probably just as big a problem.
I've also dumped at a sewage treatment plant. No questions about chemical use.
'99 Bigfoot 1500
with low loss control on the Fantastic, Dino board on the Dometic.
Torklifts and Fastguns
'04 F350 V10 Crew SRW SB 4X4 6 speed
with tow hook replacement, dual rate charging, Line-X, Timbrens.
sleepy
Oak RidgeTN
Reddog1 wrote: Boy, I feel overwhelmed. I am not sure if I can ever poop again. I am not sure if it is because the rules are so different, depending where you live, or so much misinformation. Probably a bit of both.
Wayne
Wayne, I've been to one of your parties... all you make is chocolate slurpies with that machine of yours.
2003 Lance 1161/ dinette slideout/solar cells/propane generator/Sat dish/2 Fantastic Fans model 6150/AC/winter package
Chet's AirFoil, Trimetric, LED lights
2003GMC K3500 LT/Crewcab/duramax diesel/allison/dually/4x4/OnStar/front reciever mounted spare
Reddog1
sleepy wrote: Wayne, I've been to one of your parties... all you make is chocolate slurpies with that machine of yours.
Well, you did not have to post it. Now, no one will come to one of my parties.
Wayne
Rawhyde
Ohio
I have been dumping my 5er and tc tanks into my neighbors septic clean out for years and I haven't had any problems.
BradW
Flat Rock, Alabama
As long as he doesn't find out, you should be fine.
Our Truck Camper Photos
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Visit the RV.net Blogs
