RV.Net Open Roads Forum: Truck Campers: Airfoil/ Deflector
RV.net
 > Airfoil/ Deflector
Page of 5
F100jetmech
Chiloquin, OR
Posted: 04/27/08 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
Here's my take on Sleepy's airfoil/ deflector. I made it "pointy" with a 30 degree sweep back. It uses the same gutter guard as Sleepy's, but is framed using 1x2" lumber and aluminum angle stock. Also, capped the corners with aluminium. Suprisingly light at 4 lbs.
* This post was edited 04/27/08 06:31pm by F100jetmech *
Pat
'98 Chevy K2500HD 4x4 454 c.i.
'06 S&S Montana Bitterroot 8.5 ASC
'00 Forest River Sandpiper 30SPCS 5'er
Myrtle
North Carolina
Posted: 04/27/08 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
Very nice work.
I can see you are very much a perfectionist.
If you would be so kind to explain
What is the goal and outcome of such a device?
not sure I see any advantage for an "airfoil" effect.
minimal to no increase of aerodynamics at 55-60mph
F100jetmech
Chiloquin, OR
Posted: 04/27/08 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
Myrtle wrote:
Very nice work.
minimal increase of aerodynamics at 55-60mph
It is more to keep bugs from splattering all over the bulkhead of the camper behind the truck cab, atleast that is why I built it. A few people on this forum have also reported a small increase in mpg. .
sleepy
Oak RidgeTN
Posted: 04/27/08 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
F100jetmech wrote:
Here's my take on Sleepy's airfoil/ deflector. I made it "pointy" with a 30 sweep back. It uses the same gutter guard as Sleepy's, but is framed using 1x2" lumber and aluminum angle stock. Also, capped the corners with aluminium. Suprisingly light at 4 lbs.
Nice job... good to see your thinking cap on. Have you tried it over the road yet.
When the bugs are gone so is the catchers mitt effect that the area between the cabover and truck has... your drag (cd) will be reduced.
The thread on the original airfoil is available in the tc university click here for those people that voice opinions without trying to understand how it works.
2003 Lance 1161/ dinette slideout/solar cells/propane generator/Sat dish/2 Fantastic Fans model 6150/AC/winter package
Chet's AirFoil, Trimetric, LED lights
2003GMC K3500 LT/Crewcab/duramax diesel/allison/dually/4x4/OnStar/front reciever mounted spare
nny12972
NY
Posted: 04/27/08 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Nice work! FWIW: I'd have set it up with the "point" just to the rear of the windscreen top...and made it solid. Also, just about anything that smooths the airflow helps at ANY speed. My deflector pays back 2-3 mpg depending on conditions---I figure that saved me about $400-$450 on my last R-T to SoCal with the TH.
J
F100jetmech
Chiloquin, OR
Posted: 04/27/08 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
Nope, haven't tried it on the road yet, I can't wait to see how it works. Thanks for the kudos and the inspiration to make it!
F100jetmech
Chiloquin, OR
Posted: 04/27/08 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
J
Thanks! Ya, I was thinking about putting it further back when I was mounting it. I was worried about roof clearance and hitting my head on the outer edge when entering/exiting the truck. As it turns out, it would have cleared the roof by a couple of inches. I hope it atleast makes a modest difference in bug mess and mpg. If nothing else it was fun to make!
Myrtle
North Carolina
Posted: 04/27/08 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
What opinion? I was simply asking what the goal and outcome was.
don't be such a curmudgeon!!!
you could have just said it was to help with (goal)bugs and (outcome) was less bugs and better fuel economy.
Please understand I have not seen this topic in the TC University.
petekerwien
Camano Island, WA
Posted: 04/27/08 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
What did you use to attach it to the overhang and did you seal for water? Good looking job. You could put your "handle" on it, or put RV.NET" on it.
F100jetmech
Chiloquin, OR
Posted: 04/27/08 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced some pre-existing screws with some slightly larger lag screws and washers. Between the camper and deflector there is a strip of the foam seal you put between a truck bed cap and the bed rails.
Page of 5
