RVGOODTIMES
Warren, Mi
I wonder if someone can tell me what the best method is to prep the nose of my 5ER? We are leaving for flagstaff AZ. and would like to easily remove them each day on the way there and back.
Road Runners
Tampa Bay, Florida
Good Luck. These bugs can cover and stick on most anything that hits them at a highway speeds. I don't know of anything that helps that much. I have tried pam, wax and those dryer sheets. They may help a little, but then you have to spend the time putting it on.
When en-route, if I want to rid the front cap of bugs, I take one bucket of water, one spray bottle of bug remover and one long handled truck brush. I wet the front with the brush dipped in the bucket. I then spray the bug remover on the brush and go over the whole area. It takes about two more passes with the brush, bug remover and water, but the bugs come off. Then I dump remaining water out of the bucket and go in the fiver and rest.
'05' F-250 Power Stroke
'00' 30' Cameo Fifth Wheel
mr. ed
Madison, SD (currently traveling the US)
Some folks recommend Bounce Dryer Sheets (wet them first). I haven't tried them yet but plan to because I'm going to be driving through clouds of love bugs soon...
Mr. Ed (fulltiming since 1987)
2007 Hitchhiker II LS Model 29.5 LKTG
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition
lazyboy
Alaskan relocated to Tennessee
Simple green and a bug scrubber sponge.
Eycom
Fl to NY
Just about every brand of dryer sheets I've used does a fine job of removing bugs, if you can reach them. As mentioned, wet the sheets first and wipe the bugs away. Doesn't take much elbow grease.
F-350 PSD/CC/DRW
Lance 1121-Nicely Appointed
SBSJMS
Somewhere in the Pacific NW
Dryer sheets and Windex. Spray the bugs, let it soak a minute and wipe with any kind of dryer sheets. Rinse with paper towels,it will be a mess if they are real bad, but this works like a charm and is easy. Being from TX and LA we have had lots of experience! You haven't lived until you have driven through Love-bugs for a couple of days!
HarleyMedic
Sour Lake, Texas
Amen on the Love Bugs. We use Power Purple from Auto Zone, let it soak for a couple of minutes, hit it with a brush and rinse.
Big Sexy and BonBon
2003 Dodge 2500 4x4 Laramie Cummins Auto, Edge EZ, AEM Brute Force, Timbrens, B&W.
2004 35SRV Victory Lane
1998 Harley Road King (Mine)
2003 Harley Road KIng (Hers)
1 - Jacked up, Tricked out Golf Cart. (HERS, HERS, HERS)
Hornet28BHDS
Parker, PA
I've tried the wet dryer sheets and they work well.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
ORbiker
Eugene, Oregon
On my Harley windshield, I will get a towel good and wet; then I will place it over the windshield for 10 minutes or so. This softens up the bugs and they wipe right off. I have not tried it on the camper front yet. The Oregon rain and snow has been doing a good job so far.
I (2-10-05) bought a 2002 F350 CC SWD PSD and a new 2003 Citation 10'8. Rancho 9000X & Toyo M55's.I have been a tent camper all my life. I wanted more comfort while doing my Willamette Backcountry Ski Patrol & Crater Lake Ski Patrol duties.11
LarrynBarb
NE Kansas
We use Rain-X frequently on our windshield and it seems to make the process of removing the bugs much easier. We initially use the dryer sheets along with clean water and then once they are gone we hit it once again with Windex or another coat of Rain-X.
We keep our bra installed during the spring/summer bug season and it protects the front of the motor home. The bugs will wash right off of it with a garden hose.
A friend told me that on his 5th wheel he found a good answer for the bugs. He said that before each trip he mixes about a quart of liquid Calgon and a quart of water in a bucket and then uses a long handled wash brush and he coats the entire front surface of the RV. He allows it to dry without washing it off. Then he says that after they have driven through thousands of bugs that he can use the dampened dryer sheets and the bugs will come right off. Supposedly the Calgon makes the surface so slick that the bugs hardly even stick to the surface.
I have not actually seen this done but it does make sense and I guess that it would work as well on any surface other than glass, so it should also work on any kind or a trailer just as good.
I have no idea what the Calgon would do to the waxed surface.
Maybe someone else can tell us more about that.
Larry
05 Fleetwood Discovery, 39J
07 Ford Explorer, Sport Trac, 4 x 4
Blue Ox baseplate, Ready Brute Towbar w/built
in supplemental surge brake system
FMCA, Good Sam's, Golden Age Passport
