RV.Net Open Roads Forum: Fifth-Wheels: Removing window treatments
 > Removing window treatments
chele
Ashland,KS
Posted: 04/27/08 07:48pm Link  |  Print  |  Notify Moderator
I love our "new" fiver, but I hate the window treatments! They do not match the decor at all! How can I remove them? Here is a picture:
2008 GMC 3500HD Duramax, Allison and fiver friendly flatbed!
1995 26' Excel Legacy
rick_niagara
Niagara Falls, Ontario, Canada
Posted: 04/27/08 07:51pm Link  |  Print  |  Notify Moderator
I'm sure if you look underneath the treatment, you'll find some screws attaching it to the wall.
2008 Fleetwood Prowler 235RLS
2005 Dodge Ram 2500 4x2 5.9L Diesel 3.73Limited slip 6speed manual
Pullin' 5ers since 1988....Have a nice day">
chele
Ashland,KS
Posted: 04/27/08 07:57pm Link  |  Print  |  Notify Moderator
I've looked and can not find screws! I'm thinking maybe it's a slide on type of treatment, but I don't want to get forceful with it until I'm sure of what I am doing.
rick_niagara
Posted: 04/27/08 07:59pm Link  |  Print  |  Notify Moderator
Maybe you can get in touch with your dealer or RV manufacturer.
maryshus
san antonio, texas
Posted: 04/27/08 08:34pm Link  |  Print  |  Notify Moderator
Leave the blind down and see if the screw are thru the top of the blind. All the hardware was thru the blind in our old rig. Check to see if the blind has the little latch slide at the top. Usually all the hardware in attached to the cornice then the cornice is attached to the wall.
Cheddarhead
Northern Wisconsin
Posted: 04/27/08 08:41pm Link  |  Print  |  Notify Moderator
Try grabbing the sides of the valance where it meets the wall and try sliding it straight up. They may have slots cut into the end of the valance where it meets the wall but I doubt it. Get up on a stool and look down in the top side if there is no cover. Ours are attached with small brass wood screws that are easy yo get at. There's not much holding ours on.
2006 Chevy 2500HD EC/SB 4x4 Duramax/Allison
05 Jayco "Jayflight" 285RLS
Some of our trip Pics
larry barnhart
wenatchee. wa usa
Posted: 04/28/08 08:22am Link  |  Print  |  Notify Moderator
We did this job on our first fifthwheel. Boy was it a big job. It had angle brackets that screwed to the wall. Hard to installed and take off. my wife recovered them but first I had to take about one million staples out to remove the fabic. Have fun. chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
N4ARW
Washington, NC
Posted: 04/28/08 02:30pm Link  |  Print  |  Notify Moderator
The screws holding the valance on my trailer were under the blind. Had to remove the blind to get to the screws. The blind is only held up by two screws. Hope this helps.
Sarge
Maureen (Boss)
2004 Chevy 2500HD Crew Cab
2005 Prowler Lynx 8275 5th wheel
Jake, Boykin Spaniel
JJnLilly
Ohio
Posted: 04/28/08 03:17pm Link  |  Print  |  Notify Moderator
DW did not like the panels hanging down that covered the strings for the shades so we removed all of them. On one I had to do as N4ARW indicated and remove the blind to find the screws. In our case it was not angle brackets but screws into the overhead cabinet right above the window. Makes for a nice clean look - and no more fighting those "hangie things" to do the shades...
2007 Ram 2500 QC CTD
2014 Open Range 337RLS
portablevcb
Here
Posted: 04/28/08 04:20pm Link  |  Print  |  Notify Moderator
Be careful. A lot of the stuff on ours was screwed (or stapled) in from the outside! I ended up splitting the block that was screwed to the wall with a chisel (once I found where the screw was). Then breaking off the screw flush with the wall.
charlie
2009 Dodge 2500 Double Cab Cummins
2017 Jayco Eagle 29.5BHOK
Me and Wife
Maggie the Old English Sheepdog
