RV.Net Open Roads Forum: Tow Vehicles: New Dodge Diesel..................
Search only in Tow Vehicles
 > New Dodge Diesel..................
Turbo Diesel Dude
Green Mountain, NC
Posted: 04/28/08 07:46am Link  |  Print  |  Notify Moderator
The 500 miles is for the rear gears not the engine. Engine comes "alive" around 20-25K and your milage should improve. My 5.9 kept getting better up to 50K. I consider that actually you went to the "bright" side due to the ear to ear grin (pearly whites).
charles weidman
rsh_757
Auburn, WA
Posted: 04/28/08 08:27am Link  |  Print  |  Notify Moderator
ScottG wrote:
wayne_tw wrote:
ScottG wrote:
Visaliaipa wrote:
I have a question about the ECM software. As far as updates go, is that something that owners are notified of kinda like a recall or is it up to the new owner responsible for contacting the dealer and checking for new updates or TSB's?
Congrats on the new truck and no, Dodge wont contact you. They wait until you come in with a problem and then the do the update.
However, I do not recommend getting a software update unless you need it because sometimes they sneak undesirable changes in on you.
Actually, I did get a recall notice in the mail for this.
Sometimes, but not always they'll issue a recall notice ~ it pays to educate yourself prior to getting an update. Lots of folks were angry about the backup alarm DC snuck in on them.
Doh!!!! I am one of them!!! thing scares the (expletive) out of me.
2008 Cougar 310SRX 5th Wheel
2005 Dodge Ram 2500 QC 4x4 CTD
2008 Nissan Armada LE
Visaliaipa
Visalia, CA
Posted: 04/28/08 08:38am Link  |  Print  |  Notify Moderator
Haven't seen the backup alarm.....Mine doesn't have it...as of yet. Is it like the backup alarms you hear on commercial type vehicles like trash trucks? Where does the sound originate from?...the horn or is there already an alarm thats installed but not active until they update the ECM? That would be annoying.........
Looking forward to towing with it. Can't wait to see how well the exhaust brake works going down a grade with the trailer. Part of the deal was the dealer is paying to have the Line-X spray on bed liner installed, so hopefully they do it this week befoe my trip.
Also what is this regen thing? I read about it in the owners novel. Is it something the engine computer does by itself when it gets full or do you have to do it somehow by driving it a certain wayor certain distance?
2007 R-Vision Travel Sport 27QBSS
2007 Dodge 3500 MegaCab 4x2 6.7L diesel W/4.10's, Factory exhaust brake and NAV system.
Currently residing in Visalia CA
JustLabs
Washington State
Posted: 04/28/08 08:53am Link  |  Print  |  Notify Moderator
The back up alarm they speak of only sounds when the door is open and you're trying to back up. Its actually the horn honking.
I don't know if my truck has it,because I don't need my door open to back my truck up.
The exhaust brake works great,you'll love it.
2011 Chevrolet 2500HD LTZ 4x4 CCLB Duramax/Allison
2007 Keystone Cougar 289BHS Fifth Wheel.
ScottG
Bothell Wa.
Posted: 04/28/08 08:56am Link  |  Print  |  Notify Moderator
You've got it. If you have your seatbelt unhooked and you put into reverse, the horn will honk.
Scott, Grace and Wesly
H0NDA eu2000i
ib516
Up here!
Posted: 04/28/08 05:34pm Link  |  Print  |  Notify Moderator
There is a "filter" on the exhaust called a diesel particulate filter (DPF). It traps the soot that would normally be expelled out the tailpipe. There are sensors before and after the DPF in the exhaust pipe. Once the computer senses that the DPF is getting full/clogged (because of a differential in pressure between the fore and aft sensors), it goes into "regeneration mode" and injects a small amount of fuel into the cylinder when the piston is on the way up pushing out the exhaust gasses (the exhaust stroke). This fuel the goes, unburned, into the DPF. Once in the DPF, the fuel reacts with the catalyst material inside the DPF and effectively burns the soot out of the DPF, thereby cleaning it.
I believe cleaning the DPF (regen) is done best/most completely when the truck is running at a constant speed for over 30 min or so (like when on the hwy).
All 3 current diesels (Ford Navistar, GM Duramax, and Dodge Cummins) are equipped with this system to meet the newest emissions standards.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY
Scangauge2 for Boost, Coolant temp, rail press & Trans Temp
PICS
Collision Reconstructionist, CDR (automotive "black box") download technician/analyst
mr. ed
Madison, SD (but usually elsewhere)
Posted: 04/28/08 05:44pm Link  |  Print  |  Notify Moderator
You'll love your Dodge/Cummins diesel. I tow about 12k easily with my 3500 RAM so in your case you probably won't even notice the trailer. Here are some Dodge forums you'll find interesting and informative:
www.dieseltruckresource.com
www.turbodieselregister.com
www.cumminsforum.com
Mr. Ed (fulltiming since 1987)
2007 Hitchhiker II LS Model 29.5 LKTG
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition
paztruck
San Diego, CA
Posted: 04/28/08 05:53pm Link  |  Print  |  Notify Moderator
Congrats you will love the way that oil burner tows the trailer especially when you hit the mountains.
2006 F250 Extended Cab, Long Bed, 6.0 PSD, Tow Package
2006 Keystone Springdale 242
goat66
Indiana
Posted: 04/29/08 09:21am Link  |  Print  |  Notify Moderator
If he likes his as much as I like mine he will have the 500 miles before he leaves!! I have been driving mine everywhere I go, the wife doesn't understand why we always have to drive the truck now!! My first trip isn't till May 16th, but I want as many miles as I can get before I hook up!!
2007 Hornet 30BHS
2008 Dodge Ram 3500 SRW 4x4 MegaCab Cummins 6spd Auto
http://www.gearsgarage.com/Goat1966
rsh_757
Auburn, WA
Posted: 04/29/08 10:02am Link  |  Print  |  Notify Moderator
It happens if you open the door too early, like you put it in park, open the door but maybe the ECM doesn't recognize it is in park yet, so you get a flash of a horn. After my last oil change, the service writer pulled the truck up for me, hopped out, it did the same exact thing. I said "You see what you guys did man". Actually, all you have to do is put it in park and wait 1 second, it wont do it anymore.
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
