RV.Net Open Roads Forum: Tow Vehicles: Air bag question ?
Search only in Tow Vehicles
 > Air bag question ?
radio flyer
staten island ny
Posted: 04/28/08 07:30am Link  |  Quote  |  Print  |  Notify Moderator
I have a F250, XLT, V10, 410, Camper Package. I will be towing a 2007
34FT 307RKD. This is a short bed and will be installing a pullrite
superglide this week. Will this truck need ride-rite air bags? Thanks
for any information.
donn0128
Pronounced Ore-gun
Posted: 04/28/08 07:55am Link  |  Quote  |  Print  |  Notify Moderator
No, in reality you will likely need more truck. Air bags do nothing to increase the manufacturers GVWR all air bags will do it attempt to level the truck out when it is loaded heavy.
Donn
Polishnurse
Schodack, NY
Posted: 04/28/08 08:15am Link  |  Quote  |  Print  |  Notify Moderator
You'll have plenty of truck, unless that 34' trailer weighs more then 24,000. Good luck and happy camping. Bill
As Per Ford: When properly equipped, it can pull an astounding 24,500 lbs!
donn0128
Pronounced Ore-gun
Posted: 04/28/08 08:27am Link  |  Quote  |  Print  |  Notify Moderator
The optimum word there is PULL! It does not say that you can load 4900 pounds into the bed of that truck.
Traveler II
Lindstrom, Minnesota
Posted: 04/28/08 08:29am Link  |  Quote  |  Print  |  Notify Moderator
We have automatic air bags on our truck, and I find sometime it makes it hard to hook up. If the front of the truck is down compared to the back the air system is fighting us.
Jim & Jane
2008 Cardinal 30TS
Trail Air Pin Box, Air Suspension, Smartair Air Spring Self Leveling, Reese Signature Series 18K hitch
2008 Chevy Silverado 2500HD 4x4 Duramax/Allison Ext Cab Long box
Use And Promote CB Channel 13
up2nogood
Utah
Posted: 04/28/08 08:35am Link  |  Quote  |  Print  |  Notify Moderator
The best thing I ever did was add airbags, but I do have control of them. I hitch up the 5ver push the compressor switch add the amount of air I want, and I am ready to go. They are certainly not a problem when hooking up, if they were I would be changing something.
Anson
Raleigh NC
Posted: 04/28/08 08:36am Link  |  Quote  |  Print  |  Notify Moderator
i had a 2003 F250 V-10 with the air ride system on it, i felt very comfortable towing, and also our pin weight empty on the camper was 2300 Lbs it rode and handled great.
snownyet
Western NY
Posted: 04/28/08 08:38am Link  |  Quote  |  Print  |  Notify Moderator
I tow the same trailer with a 2006 Chevy 2500HD Duramax crew cab. Unless I'm loading the truck heavy with extra gear and people I have no need for airbags, It tows and rides pretty nice. I did recently add firestone airbags for those trips when Ive got a truck full of people and a big aux tank of water in the box. I suggest you try it first without and see how it suits you, its my experience that F250 fords are spring stiffer than 2500HD chevys so Im betting it'll be just fine, the pin weight is reasonable. I also have a slider hitch and have never used the slide feature with this trailer.
2007 Montana Mountaineer 307RKD
2006 Chevrolet 2500 4x4 crew Duramax/allison
up2nogood
Utah
Posted: 04/28/08 08:40am Link  |  Quote  |  Print  |  Notify Moderator
Is this number a fact( 4900 ) or a guess, maybe you could elaborate for the OP where you came up with that number it might be helpful
donn0128
Pronounced Ore-gun
Posted: 04/28/08 09:10am Link  |  Quote  |  Print  |  Notify Moderator
OK, I can do that. Generally speaking, when hitching up a fifth wheel to any truck the pin weight will be approximately 20% of the trailers GVWR. So for the example above IF you were to hitch up a 24,500 pound GVWR fifth wheel trailer to your Ford or any truck for that matter it's approx pin weight would be 4,900 pounds. It might be a few pounds more or less, but without the benefit of an actual weight ticket from a certified scales it will be close enough for our discussion here. The 20% number is not some pie in the sky figure that was pulled out of the hat. It is a generally accepted number across the forums here. Just like saying that on a TT it's tongue weight is generally speaking 12-15% of the GVWR. More or less can adversely effect your ride and handling.
