RV.Net Open Roads Forum: Tech Issues: tank valve lubricant
 > tank valve lubricant
oldmansknees
Pittsburgh
Posted: 04/29/08 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
Check out:
http://wd40.com/faqs/#q2
bearsnob
Oregon
Posted: 04/30/08 01:22am Link  |  Quote  |  Print  |  Notify Moderator
Did I just read an anti-wd40 post? Now I think I've seen everything.
Bill, Carol & Striker The Cat
2005 Everest 323k
1989 Ford F-350 Crew Cab, 460, 5 spd, 4.30 axle
Everest owners: check out the Everest Owners Club.
Make a small loan, Make a big difference: Kiva.org
joanne0012
Boston, MA
Posted: 04/30/08 06:03am Link  |  Quote  |  Print  |  Notify Moderator
I just started a thread about this a few days ago, titled "Sticky black tank value: How to lube"
Silicone spray or plumber's grease was the consensus there, with a strong "replace it" contingent, but mine are located so they're easily accessible. Access seems to be one of your main obstacles.
WD-40 is more of a cleaner than lubricant, IMHO.
http://www.woodalls.com/forums/index.cfm/fuseaction/thread/tid/21334062.cfm
Joanne
1994 Lazy Daze 23.5' TK
eisleyr
Milton, Pa, USA
Posted: 04/30/08 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
Also be careful with WD40 and Bleach! The rubber seal on the slide can swell and cause the slide valve to move hard!!!
Rob & Kathy
97 Southwind
2004 Honda CR-V
Good Sam Member since 1992
SAR41
Evanston,Wyoming
Posted: 04/30/08 10:10pm Link  |  Quote  |  Print  |  Notify Moderator
I love WD-40. It helps keep my business profitable. What a lot of people do not know is that WD-40 will cause some rubber to swell and soften. Some Viton and buna o-rings will be ruined by WD-40. My company repairs and calibrates electronic and pneumatic calibration equipment. A lot of the operators in plants think WD-40 will fix anything, so if it doesn't work right , soak it with WD-40 and then you send it into us because it not going to work now. So I like the stuff.
OK, I'm ready to get slammed and flamed by all the WD-40 worshipers, I have my Nomex on!!
If it aint broke don't break it If you do HIDE IT!
30'Coachman E-Superduty Triton V-10 03 Ranger Toad
2 Vino 125 Scooters 500 Polaris ATV 200 Honda ATV
670 Summitt SkiDoo Snowmobile and NOT ENOUGH FREE TIME!
Wife & I with Chein(Pitt Bull,just a big baby)
