RV.Net Open Roads Forum: Beginning RVing: New RV AC Problems
 > New RV AC Problems
JohnSWA
Chandler, AZ
Posted: 04/28/08 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
Hi folks!
Weve just picked up our new 07 Keystone Springdale 179RD and we just love it! We have one problem though. The a/c worked great with my generator for about an hour and a half and then the a/c just quit! I've heard that a/c doesn't normally run from most folks generators and I may have pushed the envelope on mine. The generator is a 3500 watt chinese generator. It's really a nice genny and it has been very good to me, but this was my first suspect of the crime.
I decided to hood up the power to the trailer via the house with an extension cord and it would'nt fire up the a/c either!
I realized that the extension chord was a very small guage of wire so I went to HOme Depot and bought a 12 ga. wire 25' extension chord. While speaking with the gentleman at HD, he told me that he was an old HVAC tech and said to check the fan motor of the a/c unit. He said that if it was sitting on the lot for a while, the bearings on the fan motor might have had their grease worn or dried up!
I hooked up the new 12 ga chord and had the same old problem. No air being blown. So I went up on top of the rig and took off the shroud and tried to spin the fan. It was tight! Very snug!! After spinning it a couple of revolutions, it finally fired up! It ran for a good 45 minutes and then after enjoying a nice cool cabin with my beautiful wife... it stopped again!
What do you think? Am I doing something wrong? This is my first RV and I very well might be doing something wrong, but I really don't want to take my RV back to the dealer to have them check it out and say every thing is ok and they couldn't find anything wrong.
Has anyone else had this experience?
Thanks a bunch for your replies!
Just because you're paranoid, it doesn't mean they're not after you!
Jan_Newt
Concord, NC
Posted: 04/28/08 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
From the sound of it, you have good reason to take it back and have the dealer fix it. Something IS wrong.
Jan & Newt, Concord, NC
USCG-Ret in '94
Will be retired, retired real soon now and full timing it
2007 Keystone Raptor 3600
2001 Ford F-550
Kenneth
Washington, the state
Posted: 04/28/08 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
The fan on top is the condenser fan. It transfers the heat from the hot, high pressure refrigerant to the air. As you found, the bearings are bad and the motor must be replaced.
othertonka
Stockton, CA
Posted: 04/28/08 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
I think you answered your own question. When you took the shroud off and tried to turn the fan, it was "tight". after you turned it a few turns it worked for 45 minutes. Did you go back on top and see if the fan was "Tight" again? If you had, you would probably found out that the fan was stuck again. I would say that the motor has bad bearings/bushings. Also I would not run that AC with a 15 amp extension cord. That AC takes quite a bit to "start" it. Take it back to the dealer and have the fan motor checked and then try it on a 30 amp circuit
Othertonka
2004 Southwind 32VS
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
JohnSWA
Chandler, AZ
Posted: 04/28/08 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, guys! I really appreciate the info!
H4Adventures
Minot, North Dakota
Sounds like warranty work to me too. I would take note of how they treat you on the warranty work after the sale too, sometimes it's difficult to get the dealership to work on things but not always. I say this because this is when you find out how good the dealership really is...
2007 Zinger ZT30BH
2008 GMC Sierra 2500HD CC, 6.0/4.10
2004 Chevy Trailblazer
2003 Tracker Avalanche, 150EFI Merc.
tvman44
Southwest Louisiana
Posted: 04/29/08 07:52am Link  |  Quote  |  Print  |  Notify Moderator
Bring it back to the dealer, you lhave a bad fan motor.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
TWhaylen
Colorado
Posted: 04/29/08 08:49am Link  |  Quote  |  Print  |  Notify Moderator
I had heard that you shouldn't even run your A/C when it is plugged in at your home but only for a few minutes as it draws to much power?? They said it will fry the cord. Is this true?
2005 Surveyor SV234
2004 F-150 Supercrew Lariat w/5.4L/3.73 Gears
Voyager Brake Controller
Reese Friction Sway Bar
beemerphile1
NE Ohio
Posted: 04/29/08 11:13am Link  |  Quote  |  Print  |  Notify Moderator
No, it is not true as stated. You should have a 20 amp circuit with a minimum 12 gauge cord. Watch the voltage, if it drops too low it can cause damage. I think the number is around 108 volts, someone else may know for sure. Do all that and you will be fine.
Tim
"Okay, I admit it, the only thing I'm really good at is being me."
Support the "No Child Left Inside Act"
2006 Weekend Warrior FK1900
1998 Ford E150 4.6L
1996 BMW R1100GS
2005 Trek Madone 9spd.
1995 Burley tandem
JohnSWA
Chandler, AZ
Posted: 04/29/08 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, guys! The dealer wants me to bring my genny to the shop. They want to measure the power coming from the genny, but that shouldn't have anything do do with it failing when it's hooked up to the house with the 12 ga chord. I'm going to make sure they take off the top shroud and spin the fan to see if it spins freely. Thanks again for the advice!
