RV.Net Open Roads Forum: Class A Motorhomes: Yet Another Fuel Filter Thread
 > Yet Another Fuel Filter Thread
Norm Payne
Livingston, TX
Posted: 04/29/08 09:16am Link  |  Quote  |  Print  |  Notify Moderator
kenbert wrote:
Norm, It is a mechanical engine.
Thanks for your reply. My take is different engines have different requirements and it is best to follow the owners manual that came with your engine. If in doubt call Cummins or CAT. There are different ways to prime the fuel / purge the air from diesel engine fuel systems. So there is no one answer that fits all engines.
Norm
2005 Dutch Star 4015, Cummins ISL 370 hp
2007 Honda CR-V
See Ya Down The Road
http://www.seeya-downtheroad.com
Lentz
Three Rivers, CA
Posted: 04/30/08 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
I have an '03 Endeavor and I fill one filter, reinstall, click on switch then start engine and let run short period of time then do second the same way. Have had no problems.
Wayne
Lentz
Three Rivers, CA
Posted: 04/30/08 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
I have an '03 Endeavor and I fill one filter, reinstall, turn on key a couple of times and then crank engine let run short time and repeat the process for the second filter and have never had any problems.
Wayne
Rhigley
Downey Ca
Posted: 05/02/08 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
I just did my Cat today and I installed them dry and did the hand pump for 45 min. before I removed them and filled the filters and pumped about six more times and started the eng. For mine filling the filters first is the way to go.
2006 Cheetah DP .Prodigy. 2006 Rhino 660 LE...On the road again!
Amatuer Radio KF6OOK
LLT
VA
Posted: 05/09/08 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
A trucker told me to fill both filters with PowerService, so I did. I cycled the key 5 times (30 seconds in between) and started it. Ran on fast idle for 5-10 minutes, purring like a kitten. Shut it off and restarted and it fired right back up.
Nerve-racking for sure!
Thanks again.
wolfe10
Posted: 05/09/08 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
LLT,
It is quite possible that your coach setup allowed fuel to drain from the primary fuel filter back to the tank when you removed the filter, leaving a LOT of air for the manual pump to move.
A shutoff valve at the inlet to the primary filter would solve that.
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
Deen
Vancouver, WA
Posted: 05/09/08 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
Norm Payne wrote:
I have always installed the fuel filters dry in my Cummins engines and do the key procedure to purge the air. Sometimes I have to pruge more times than the instructions say, but the engines have always fired right up.
Both Cummins and Spartan told me to install the filters dry.
My manual says to install dry and follow the priming procedure, so I do. Never fialed yet.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
