rotwiler
WA
I recently bought a Itasca class A 99, 32.2 foot. Could see brown stains around sunroof in bathroom and by front door. I'm kinda picky and was going to use the carpet cleaner put had some fears I would set the stain in and never get it out. I was at home depot and bought a product Zep Oxy carpet and fabric cleaner. States it needs no scrubbing, stains just vanish. I thought for $4.49 I could try it. I sprayed a steady stream overlapping the areas(which were about 6 inches wide by over 2 feet. Stain turned darker and I was saying to myself, I just made it worse. Being a little mad I went into the house and brought out my carpet cleaner. Looked up and stain was gone. I was a happy camper lol I let it dry for a couple days and you can see a faint color area around edge that it didn't remove the stain all the way so will need to go over it one more time. It looks so good now I probably should just leave it alone, but it works is what matters. It must contain some type of hydrogen peroxide since it
turned my finger white like hydrogen peroxide does when it gets into a cut. Scrubbing the area with warm water and blotting it dry makes it work better. I did that in another area with great results.
After I did that I went out and bought a few more bottles of it. Even used it in the carpet cleaner. I sprayed the fabric on the bottom of the captains chairs that was dirty(looked like engine grease etc) use a cloth the rub it in and then my carpet cleaner to throw clean water on it and suck it up and it came clean like new. Even a rv shop that flushed my brakes yesterday, called me to ask what it was again to buy some, I showed them the area I cleaned and they were impressed on how it looked. Total time to do the entire interior of my 32 footer was less than 2 hours.
Also read somewhere that hydrogen peroxide and some baking soda works too, but I like the Zep stuff, so will use that.
edited 04/29/08 12:06pm by rotwiler *
Itasca Sunrise 32.2 454 FI
othertonka
Stockton, CA
Is this what you are talking about? Zep Oxy
Othertonka
2004 Southwind 32VS
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Hornet28BHDS
Parker, PA
Thanks for the good product review!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
rotwiler
WA
Well says in description zep, but bottle name is different on that one. The one I have is blue and says Zep Oxy Carpet & Upholstery Cleaner.
jojolou
S. E. Michigan
We had a similar problem with a ceiling stain. I used a 50/50 mixture of water and bleach in a spray bottle, it worked like a charm!
Lou
2008 Allegro Bay 35 TSB W-25.5
donn0128
Pronounced Ore-gun
I have always likes ZEP product. They make a really good scouring powder. Unformulated that stores do not carry it and now Home depot is getting rid of it. At least in our area.
Donn
rotwiler
WA
Another good scouring powder is Bar Helpers Friend(pretty sure thats the name), they have it at home depot also. Friend told me about it to clean the bottom of a shower etc, I used it on my stainless steel sinks and worked good. Plus it is cheap at about $1.90
richy1
leesburg,fl.
Kilz makes a product called "upshot" it's made specifically for ceiling stains. I have used it in manufactured homes on ceiling tiles and popcorn ceilings with great results. I would not hesitate to use it in an rv.
