RV.Net Open Roads Forum: Fifth-Wheels: Bedsaver for slider hitches
 > Bedsaver for slider hitches
Don & Carolyn
North Branch, MN
Posted: 04/30/08 06:43am Link  |  Quote  |  Print  |  Notify Moderator
Can a Bedsaver be used on a Reese SLIDER hitch or will the Bedsaver interfere with the sliding mechanism?
Thanks,
Don
D&E Johnson
Ontario Canada/Brenda Arizona
Posted: 04/30/08 07:01am Link  |  Quote  |  Print  |  Notify Moderator
not an expert here, when we bought our 5th wheel last May,(we have the husky slider hitch) we had to take out the bedliner. Was told the spray on kind was ok, but not the liner we had. The liner is sitting in the front yard, and its for sale, as is our high rise cap..
I'm sure more knowledgeable folks will have a good answer..Dona
Dona and Elvin
2004 6.0l F350 turbo-diesel/4x4/crew cab/shortbed-wedgewood blue)
2007 Open Road 359RL3S
2004 Yamaha Kodiak 400 ATV
Retired early and ready to see North America!
SpoiledRotten
Central Mississippi
Posted: 04/30/08 07:12am Link  |  Quote  |  Print  |  Notify Moderator
D & E Johnson, He is talking about a piece of equipment that attaches to the hitch to catch the 5er if it should come out of the hitch by mistake.
My Bedsaver comes within about 4 inches of the back of the hitch (where the pin goes into the hitch). I wouldn't think that would give a slider nearly enough room to work. If your slider doesn't go back any further than that, I can't see any reason to have a slider. I would have to say no and hope this helps.
* This post was edited 04/30/08 07:26am by SpoiledRotten *
Just the 3 of us...SpoiledRotten, TotallyRotten, and ALittleRotten
2000 F-250 Lariat, CC
7.3 PSTD-Superchipped
2005 33RL2 New Vision - AKA "SpoiledRotten"
2000 Jeep Wrangler Sahara Edition
CactusJohn
Scottsdale, AZ
Posted: 04/30/08 08:46am Link  |  Quote  |  Print  |  Notify Moderator
As you can see in my sig, I have the BedSaver attached to my slider and there is no problem. In fact, I wouldn't want to be without it. I was talking to a service tech in Phoenix (not my dealer), and he said they average one repair per week of a 5er that’s been dropped on the truck's bedrails. The cost is about $1K for the 5er and up to $4K for the truck. The BedSaver is very cheap insurance.
2007 Ameri-Camp Summit Ridge SF27RK 5er
2008 F250 Lariat SuperCab, 6.4L PSD
Reese 16K Kwik-Slide with BedSaver
CactusJohn
Scottsdale, AZ
Posted: 04/30/08 08:49am Link  |  Quote  |  Print  |  Notify Moderator
One other thing, the BedSaver attaches to the slider and, therefore, moves with it. Go the BedSaver website and take a look.
UTCUMMINGS
Waco, Texas
Posted: 04/30/08 09:02am Link  |  Quote  |  Print  |  Notify Moderator
I do not know why you had to remove your bedliner. They could have just cut out the piece that interferes with the rails. At least thats what I did and still was able to keep the bedliner in. No problems to this date.
geeman53
springfield,ohio
Posted: 04/30/08 09:14am Link  |  Quote  |  Print  |  Notify Moderator
I've got a Bedsaver on a Reese 15K slider with no problems.
Gman
Ford superduty, Bedsaver, Heartland Sundance-"Buckeye Express"
silverfoxn
Georgia
Posted: 04/30/08 09:15am Link  |  Quote  |  Print  |  Notify Moderator
To answer your question: Yes you can use a bedsaver with the sliding hitch. I can not use the bedsaver because I have a tool box behind my hitch and the bedsaver would hit the box. When making the hitch they could install a removeable pin just behind the keyway of the hitch and then a bedsaver would not be needed. Two bushings welded in place and a hole drilled is all that it would cost. I guess that selling the bedsaver is better for the company than thinking about making the hitch safer. I would be careful using a bedliner with holes cut in it. Water can freeze under the liner and damage the liner, truck bed or both.
Jesse & Karen Norris with Kirby our chow-chow
2005 HitchHiker II LS 29.5 LKTG
2005 Dodge Ram 2500 Turbo Diesel
Martinez, Georgia
SpoiledRotten
Central Mississippi
Posted: 04/30/08 09:37am Link  |  Quote  |  Print  |  Notify Moderator
If you get a chance, would you post a pic of the set up you have. I don't have a slider, but have the BS. Just for cureosity sake, I would like to see how the slider has enough room to slide unless the BS slides back with the hitch. I wouldn't have though they did that. Hmmmmm...
On the Bedsaver website, I don't see them actually attached to the sliders. It looks like they have one pic for all applications.
CactusJohn
Scottsdale, AZ
Posted: 04/30/08 10:03am Link  |  Quote  |  Print  |  Notify Moderator
Sorry, I don't know how to post a picture. I just tried and it didn't work. Advice? Anyway, the BedSaver is attached to the side of the hitch, not to the slide rails. So when the hitch slides, the BedSaver slides too.
