RV.Net Open Roads Forum: Tech Issues: Mounting a small shelf in bedroom slide
 > Mounting a small shelf in bedroom slide
firefighter33
Youngsville, La. usa
Posted: 04/30/08 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
I would like to mount a small shelf over the head of the bed in the bed room slide. Does anyone have any suggestions as to how to mount and secure the shelf. The shelf will be attached to two 90 degree wood braces, but what is the best way to mount the braces to the wall? I hate to put screws into the wall not knowing what is on the other side of the wall. Should they have some sort of studs or support in the slide that would be solid enough to secure the brackets. The shelf weighs about two (2) pounds and will be used to hold the TV remote and an alarm clock. I made the shelf myself out of 1/2" light weight wood with a small ledge around it to keep the items from falling off. Any ideas would be appreciated.
Louisiana Firefighter 38 years, SOON TO RETIRE
2007 Ford 3/4 ton powerstroke, 2009 Sundance Heartland 30'
eisleyr
Milton, Pa, USA
Posted: 04/30/08 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
First is your framing wood or metal? then use a 'stud finder' (Lowes or Home Depot) and use right screw for framing type. Another idea: IF your total load is under 5lbs try the Scotch picture holders (no holes needed!) but still may want to use them over a stub area so wall doesn't bow in time with even light weight.
Rob & Kathy
97 Southwind
2004 Honda CR-V
Good Sam Member since 1992
CA Traveler
Sun Lakes, AZ
Posted: 04/30/08 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
Use a stud finder for starters. Then on a cool morning take pictures of the condensation patterns on the outside, take pictures of the entire outside for future projects. Should match the stud finder. Contact the mfg for a structural drawing. Remove lights or anything else that will allow you to probe with a wire through any insulation to find the studs.
2004 Holiday Rambler 36 Endeavor PST with ISC 330 Cummins
2004 Honda CR-V
Bob
firefighter33
Posted: 05/01/08 04:39am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the information. I have bought a stud finder, but it does not seem to work on my walls. Should it work on aluminum studs? I bought it at lowes and they could not tell me if it would work or not.
I am considering the double stick tape.
thanks again
wayne_tw
South Dakota/Georgia
Posted: 05/01/08 06:38am Link  |  Quote  |  Print  |  Notify Moderator
Gosh, including the shelf itself, you will only have about 3 lbs of weight. The paneling itself will hold that with just screws. Alternatively, you could line the shelf back edge where it mates with the wall with a good quality double sided tape designed for this purpose.
Wherever I happen to park
Posted: 05/01/08 07:10am Link  |  Quote  |  Print  |  Notify Moderator
If I'm not mistaken 2 pounds is within range for 3-M Command Adhesive Strips
They work great
However, I'd not be too concerned, if it's an outside wall, and there is no light or plumbing on it, odds are you have 1-2 inches of Styrofoam and then the outer skin You might hit a stud, this would be a good thing
Navychop
Fairfax, VA, US
Posted: 05/01/08 09:06am Link  |  Quote  |  Print  |  Notify Moderator
When we looked at the rig we eventually bought, the lack of shelf space by the bed was a deal killer. Sales critter said he'd install two shelves for us. He bought some triangular shelves from Target and put one up in each corner. Small, just the size we wanted, brown to match the decor. We can see some caulk was used. I don't know for sure how they are attached, but I suspect it's glue and caulk, period.
2004.5 Dodge 3500 Laramie Quad LB SRW CTD 48RE 4.10 4x4
97 30' Coachmen Royal TT traded in April '08 on a
2008 Keystone Challenger 35CKQ fifth wheel
Air Safe 25K air hitch
Kipor 3500Ti (avoid- no support)
