RV.Net Open Roads Forum: Fifth-Wheels: EUREKA!!! LEVELING IDEA!!!!!
 > EUREKA!!! LEVELING IDEA!!!!!
crickeydog
Marietta, Ga.
Posted: 04/30/08 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
ATTENTION 5TH WHEEL MANUFACTURER'S: Instead of charging us $4K+ for a "Big Foot" or similar 4 point electric or hydraulic leveling system which most of us don't want on our 5'er anyway, give this some consideration if you haven't already done so. Make center point suspension airbag's an option with 3" of vertical travel. Install an onboard 110 volt air compressor capable of reinflating the airbags independently. When we unhitch our 5'er, we level side to side using the suspension airbags by inflating or deflating the suspension airbags! Any more than 3" and you wouldn't park on a site that unlevel anyhow! Then as usual, we can level front to back by raising and lowering the front landing jacks which you have to do anyway to unhitch. Whadda ya'll think??? Boooyahhhhhh!!!!!!
Happy camping!!! See ya'll down the road!!!
AIR FORCE RETIRED "EITHER LEAD,FOLLLOW,OR GET OUT OF MY WAY"!
2006 GMC 3500 SLT CC DRW 4X4 D/A LBZ,PREDATOR & FS2500 OIL FILTER
2004 HR PRESIDENTIAL 30 SCD 5'ER.
CHEROKEE & CHEYENNE, MINI DOXIE'S
LOADED LIKE A FREIGHT TRAIN, FLYIN LIKE A JET PLANE!!
rusticwood
Seymour Mo
Posted: 04/30/08 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
You could just load the compressor in your truck or fiver and when you get there and need to raise one side a couple of inches just let the air out of your tires on the other side to level out. When you are ready to leave just air your tires back up to normal inflation pressure.
Fatbob
el paso tx
Posted: 04/30/08 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
I thought about doing that with some ride rite air bags I removed from my f-150. Too bad they didn't have enough travel though.
Anyway that would be a great option for a 5er. Maybe someday they'll design one.
wolf396
wichita
Posted: 04/30/08 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
great idea! now somebody needs to try it.
'01 26' keystone hornet, '99 silverado 2500, '80 glastron cvx18
Alan_W
Longmont, CO USA
Posted: 04/30/08 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
And bounce up and down, just like on a trampoline
Alan & Cathy
Brittany 14, Cody 11, Brooke 9 and Allison 5 -- Rig and Trip Photos Website
NGRRFan
Colo. Spgs., CO
Posted: 04/30/08 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
Somebody did try that and found it too expensive to produce. Their research showed it would only work on larger trailers that had space for the compressor and air tank plus switches and valve assembly.
They then shifted their attention to an air ride centerpoint suspension system which was more economical in the long run, both for them and the consumer.
Rich,and Tobi (the rescued dog)
Prowler 5ver, 84 Ford F250
KCOCOLOR78 Weather
Colo. Spgs. CO
PackerBacker
Montreal, Quebec,Canada
Posted: 05/01/08 03:33am Link  |  Quote  |  Print  |  Notify Moderator
How do you contain vertical linear movement while traveling with the airbags deflated? The present suspension allow wheels/axles to travel up and down within spring system. To lifting the chassis above the axles to level may require some sort of mod in order to gain enough travel. I'm not sure it would be the same as when you jack up a vehicle using the frame and having the wheels hang down.
Interesting though.
* This post was edited 05/01/08 03:44am by PackerBacker *
Eric
2009 Holiday Rambler Admiral 33SFS
Good Sam's - FQCC/Camping Quebec
My Photos
thecampingman
Wilmington, OH, USA
Posted: 05/01/08 04:08am Link  |  Quote  |  Print  |  Notify Moderator
I think someone already offers that. But I've been to so many camper shows and read so many fliers I can't remember who. But their system was more for leveling the load for traveling.
But I'd think it would help with leveling for parking too.
I've considered modifying my own centerpoint system to a two line system. All it would take would be some more of that little plastic tubeing, another gauge and a schrader valve. Probably cost less than $25. And the littlest chicken-heart 12volt compressor in the world would pump up to 30psi. And the volume of the air bags is like a bicycle tire, so it would have fairly quick response.
Tell you what, you try it and let us know how you like it. Then maybe I will.
'03 GMC 4500 Duramax/Allison
'04 36' McKenzie Medallion triple slide
Snowbird W/Ohio camper dock
DianneOK
Sioux Falls, SD
Posted: 05/01/08 06:53am Link  |  Quote  |  Print  |  Notify Moderator
I'll keep my BigFoot, thank you
Dianne
Fulltimers (9 years)
Volunteering/workamping
Ambassador RV Resort, Caldwell, ID for the winter
DataStorm
HAM WB6N (Terry)
2005 Teton 39' Frontier Grand
2003 Freightliner FL60
Life Member Good Sam
Escapees
Geocache..."RVcachers"
RV net Blog
1414141414
East Islip
Posted: 05/01/08 07:50am Link  |  Quote  |  Print  |  Notify Moderator
I open my refrig if the door swings to one side I raise the side up it cost nothing
