RV.Net Open Roads Forum: Tech Issues: power help!!!
 > power help!!!
JohnnyD111
Cape Cod, MA
Posted: 04/30/08 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
My coachmen was plugged in to the house, i unplug it for a min to use the extension cord then plug it back in and no power.... I checked all fuses and breakers. I got a new intellipower inverter last year. Do you think the inverter already went? Any thoughts? what is the voltage soppose to be the the inverter plugs into, I checked shore power and its 120. I thought it converts 120 to 12....????
Johnny D
92' Coachmen Leprechaun 29ft Class C
eisleyr
Milton, Pa, USA
Posted: 04/30/08 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
Check for 120V at the plug where the convert is plugged in at. If you have volts the problem is on the 12 volt side. If you don't have volts the problem is on the 120 volt side. 120 volt side: start at the shore power and work your way to the converter. 12 volt side: if your below 12.6 volts... probably converter.
Rob & Kathy
97 Southwind
2004 Honda CR-V
Good Sam Member since 1992
JohnnyD111
Cape Cod, MA
Posted: 04/30/08 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
well there isnt 120 at the plug for the converter... so does this mean theres a break in the line, cause isnt it just the shore line cable into the converter, then the rest of the camper is fed off 12v? Could it be a GFIon the converter? is there a GFI in the converter?
JohnnyD111
Cape Cod, MA
Posted: 05/01/08 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
is there an inline fuse on the shore power line?
CA Traveler
Sun Lakes, AZ
Posted: 05/01/08 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
The converter could be connected to a GFI. Reset all bathroom, kitchen GFIs in the rig. Toggle all CBs fully off then back on. Sometimes they look on when they are not.
2004 Holiday Rambler 36 Endeavor PST with ISC 330 Cummins
2004 Honda CR-V
Bob
Bubby's RV
CA
Posted: 05/01/08 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
Did you trip the breaker or a GFCI in the house?
John, Winnebago Minnie 24V
Wherever I happen to park
Posted: 05/01/08 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
CONVERTER (Intella power is a Converter one of the best in fact if it's a 9200 series or a 9100 with optional charge wizard) converts 120 vac to 12 vdc
INVERTER.. Goes the other way around (Inverse of converting)
Check outlet you pulg rig into. you may have tripped either a breaker or a GFCI in/on the house
Check all breakers in the rig Don't trust your eyes FEEL the breaker's lever
(I have not checked for tripped breakers by sight for 30 years)
Then we have to break out tools
JohnnyD111
Cape Cod, MA
Posted: 05/03/08 10:33am Link  |  Quote  |  Print  |  Notify Moderator
were down bourne scenic park now and everything seems to be working... odd... maybe the drive down knocked something back into place.... ill have to investigate
Posted: 05/03/08 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
Re read suggestions above to re-check the outlet at the house.
I'm guessing you popped a breaker or GFCI in the house
JohnnyD111
Cape Cod, MA
Posted: 05/05/08 08:12am Link  |  Quote  |  Print  |  Notify Moderator
yea I checked it, but it was fine.... I dont know,
 > power help!!!
