RV.Net Open Roads Forum: Class C Motorhomes: Decals
 > Decals
sgtks84
Ohio
Posted: 05/01/08 06:35am Link  |  Quote  |  Print  |  Notify Moderator
What can you do about decals that are fading and peeling? These decals are on the side of a 30ft class c on fiberglass.
rob85546
Hot arizona
Posted: 05/01/08 06:43am Link  |  Quote  |  Print  |  Notify Moderator
Dont even know why they put them on..Look good to sell I guess. they fade and peel so fast, especially in Arizona,,
Use hair dryer, heat them peel them all off and buff out.... leave or contact manufacturer and see if you can get more.... My last TT I just peeled them off.....
2007 GMC DURAMAX,LBZ,4 by Crew, Allison
Magnaflow Turbo Back Exhaust
Predator Tuner
18by9 Helo's on BFG's
5year old boy
3 year old baby girl
Sea ray boat
Wilderness 5th wheel
SandRail
HD WideGlide
FORD Expediton
honda Eu3000
jauguston
Bellingham, WA
Posted: 05/01/08 08:27am Link  |  Quote  |  Print  |  Notify Moderator
If you decide to remove the decals you will find the surface under them will not be the same color as the area that has had the sun on it. I removed the stripe decals from my previous class C. I masked the stripe area and spray painted them back in.
Removing decals is not a easy job but the best thing I found was a decal eraser that came from a auto body supply store. It is a 3" diameter wheel made from eraser material and it has a 1/4" shaft to use in a electric drill. It works very well.
Jim
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210
275 RV injectors
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
kendall69
Palm Springs California
Posted: 05/01/08 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
Take the decals off,and get a good buff and wax and all the colors will blend, new to old, if not right away, in a while as the sun hits it.
2002 - Bigfoot M-29G, 2004 Jeep Rubicon Toad
MikeMike
St.Petersburg,Florida
Posted: 05/07/08 03:34am Link  |  Quote  |  Print  |  Notify Moderator
Although not bad, one side has had more sun and I have thought about the solution also-mine are metallic maroon and blue. Maybe time for some real spray on metallics or custom flake-two days work and no more stick on plastics that shrink and split.
 > Decals
