Skycap31
Vaudreuil-Dorion
Hi I wonder if someone could tell me where the reset button is on a suburban heater? I have a Rexall Aerbus and the heater stoped all of a sudden.The Trailer Life RV book ststes that I should reset the heater,well I am new at this and need some help.Would appreciate it.
Thank you in advance.
John
Nick Badame Refrig.
Cape May Court House, N.J.
Hi John,
I think you are talking about the Hi Limit Switch.
It's mounted on the housing of the blower. It may have a resettable bi metal switch that has a red button in the middle of it. Look for two wires of the same color leading to the blower area.
More then likely, something failed to have tripped it!
Good Luck
Nick-
MCI 102C3 40' 2006' Bus Conversion by Atlantic Custom Coach
Detroit 475hp 8V92t w/Allison Ht750 auto
Master Mason, Cannon Lodge #104 S. Seaville N.J.
FMCA# F-27317-S
cmartin7143
ILL
None that I can think of other than re-setting by turning the switch on and off. Most I ahve seen reset when the water cooled. the limits are around 130 operator and 200F limit. both are under the card board or plastic box inside near the water connection. They look like oval buttons with two wires coming from them and are clamped firmly to the tank. if one has a manual reset it will have a red button in the center. My big consern is why it got too hot? Some where on the unit there is a wiring diagram that should help. they may maybe maked TC (temp control). Wish I could be more help. good luck
Never mind was thinking hot water heaters. Yes furnace does have re-set.
Skycap31
Vaudreuil-Dorion
Thanks Nick will check it out tomorrow morning.
John
jwmII
out west
Assuming this is a furnace and not a water heater there will be no reset internally as has been described. The reference to reset is referring to the thermostat where you set temperatures. Just simply turn it off and back on at the T-stat, and if the electrical supply is adequate the furnace should go.
jwmII
Skycap31
Vaudreuil-Dorion
Hi it is the heater furnace,when I turn it on I hear a click but nothing happens I changed the fuse the first time it happened but the second as I mentioned nothing goes just the click from the thermostat
Thanks, jwmll
John
jenks60
MS. coast
SUBURBAN FURNACE
BRYANT RV MANUALS
edited 05/02/08 02:59pm by jenks60 *
jenks, fulltiming with the DW.
92 Southwind P3(32) 33 ft.
99 Saturn SL2
Rallys attended-TX 2, LA 2, MS 1, AL 2
MA. 1 drop in for visit.
Skycap31
Vaudreuil-Dorion
Thank you very much jenks60, this will answer my Question.
John
