cybervanner
Richmond, VA
The water pump in my new TT is extremely noisy. It shakes and vibrates the entire TT when it comes on, and can even be heard outside. I figure it's just a cheap OEM pump, and figure that one of the nicer pumps avaliable in the catalogs may run quieter. Before I lay down $150 or so for a new pump, has anybody else had any experience with the higher-end water pumps to say how much quieter that they are? I know household well pumps make no more noise than a running fridge, are the better RV WP's like this too? I did notice that some of the pumps run up to 65 PSI verus my current one at 40 PSI. That ought to make for a better shower.
BlackSilver
East of Heaven, North of Hell
I put an accumulator tank on my camper, and it did two things....
1 -- quieted down the pump noise.
2 -- pump runs less frequently (accumlator acts as a "pressure reservoir")
Hans, KØHB & Colleen, KØCKB
Master Chief Radioman, US Navy
'04 Prairie Schooner 34FBR Platinum XL
'08 3500HD Silverado Big Dooley LTZ Go-power by Max & Allie
My rig (Click)
mike4947
N. Syracuse, NY
The common fixes for noise reduction are first isolate the pump from it's mounting surface. For some reason builders love mounting the pump to a large flat surface that acts like drum head when the pump comes on increasing the noise a couple hundred percent.
The next step is to replace a portion of the input and output lines with reinforced flexible tubing if the builder has used more rigid tubing. And to make sure the rest of the tubing isn't resting on something that acts like a resonator.
Even the quietest pump can be noisy if the above wasn't followed in the installation.
Accumulator tanks can help with the noise and pulsing, but remember once they supply the volume they hold the pump will come on and run longer to build the pressure back up AND to refill the accumulator.
As for the shower, we've found it's more in the shower head than the pump. Take a look and see it you can separate it. If you can you'll wind a restrictor washer of some kind used to reduce the VOLUME down to the 1.5 GPM. Pulling it will increase the flow to whatever GPM and tubing will allow.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
Want to sell some of your gear? -
Free Classified Listings on RV.Net
They say you learn by your mistakes, in that case I must be a genius.
Mark Heisler
Viking,Alberta Canada
Hi
there's lot of pump have the hard/stiff hose going into them and out. you need to put two or three feet of soft flex water hose on the out side of your pump and this will cut down on the noise this is about a 5-10 dollar fix . you need two hose barbs 4 hose clamps and 2-3 feet of soft water line hose( same size as your water line)let me know if this works. what your getting a vibration of the water line through the pump
2003 dodge 2wheel drive diesel 375hp 750torque
2007 citation fifth wheel model 29bhs
LAdams
Northern Illinois
Like Mike said, the common fixes are:
1. Noise Isolation Mount on water pump
2. Flexible Input/Output water lines
3. Accumulator Tank (2 gallon suggested)
4. Foam pipe tubing on water lines that contact floors, walls, etc...
My setup below - it is so quiet you can't hear it run unless you open the front pass through hatch...
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
** NEW ** blog.rv.net
bill h
el segundo
My pump is shock mounted etc, as above, and is super quiet. But, whenever I let the tank run empty or almost so, it gets really loud. Seems to be air in the lines. On refill, it sometimes takes a couple of days to get quiet again.
Bill and Susan
84 Barth 30 tag powered by ht502/Thorley, Gear Vendors OD
Siamese Calvin and Airedale Hobbes
4WD Toyota toad
Harvard
51.37N 114.42W
bill h wrote: My pump is shock mounted etc, as above, and is super quiet. But, whenever I let the tank run empty or almost so, it gets really loud. Seems to be air in the lines. On refill, it sometimes takes a couple of days to get quiet again.
I agree, make sure you get all the air out before spending $150.00.
Bubby's RV
CA
On my Minnie, the water pump has rubber feet to isolate the pump noise from the floor. The factory tightened the screws down so tight that the rubber was compressed flat. I loosened the screws so the rubber could flex and it made a world of difference. Cost = $0.
Also, make sure they used flex hose on the inlet and outlet.
John, Winnebago Minnie 24V
BurbMan
Long Island, NY
My set up is similar to Les'. You need to isolate the pump so the surges don't reveberate through the hard PEX plumbing. I used a stainless faucet hose from the local big orange store...
LarryJM
NoVa
cybervanner wrote: The water pump in my new TT is extremely noisy. It shakes and vibrates the entire TT when it comes on, and can even be heard outside. I figure it's just a cheap OEM pump, and figure that one of the nicer pumps avaliable in the catalogs may run quieter. Before I lay down $150 or so for a new pump, has anybody else had any experience with the higher-end water pumps to say how much quieter that they are? I know household well pumps make no more noise than a running fridge, are the better RV WP's like this too? I did notice that some of the pumps run up to 65 PSI verus my current one at 40 PSI. That ought to make for a better shower.
I doubt if it is your pump or even how it's mounted unless as someone already posted they overtightened the screws in the shock mounts. Most water pumps already have some flex hose in the inlet and outlet, but a major source of noise in where those flexible lines mate to the hard lines and how the hard lines are secured. I would recommending putting either some rubber or hard foam under the union where the flex mates to the hard line and then a conduit type clamp about 3 inches down on the hard line and then another about 6 to 7 inches from the first. Most of the noise IMHO is from the flex lines vibrating the hard line and it bangs against the floor or even some vertical surface. My fix is probably under $2 for the conduit clamps and you might even have some of those already. Below is how I did mine:
By just doing this I made my water pump so quiet I can't hear it unless I either open the cabinet or put my ear right next to it. I need to at least hear it so if I hear it cycling I can find the leak and fix it.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974. TRAILER MODS
