RV.Net Open Roads Forum: Travel Trailers: Storing the blue holding tank when traveling??
 > Storing the blue holding tank when traveling??
Lantley
Ellicott City, Maryland
Posted: 05/04/08 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
I carry mine on the ladder with the help of a folding chair rack from CW and bungee cords
01 PSD X,06 Trailvision 31BHDS Edge Evolution
4"exhaust,AFE,C-Betr,Tornado
Firestone air bags,TomTom,Atwood 3500
Hensley,Prodigy,exhaust brake,Swift Hitch
14'PortaBote9.9hp,6"PVC,Thule,Combi-Cam
Toppoprails,Bodiak,Sherline,Maxx Air
Subaru 4300is w/Gen Box
becky.largent
Bloomington, il
Posted: 05/04/08 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
We squeeze ours between the propane tanks and the battery and use a couple of bungies to add some extra support.
woodworker40
Western Pa.
Posted: 05/04/08 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
crappie_fisherman wrote:
I know Les USED TO carry his on the rear!
I had this bracket fab'd up at my local welding shop.
I only have a 15 gallon blue tote...I find it easier to handle...weighs next to nothing empty
Good luck,
joe.
I did the same thing as you did. I made the bracket and I just place the tank in it and strap it down.
MaddogBC
Kelowna BC
Posted: 05/04/08 10:44pm Link  |  Quote  |  Print  |  Notify Moderator
Just finished mine tonight
Leaves enough room left over for some extra extension cords and a couple fold up chairs. I built it with pressure treated wood and coated it many times with Olympic wood stain and all fasteners are galvanized. Quite cheap to make including hardware, but being fussy in the details sure takes alot of time. Worth it though, I suspect it will outlast the camper
niceleyc
knoxville tn
Posted: 05/06/08 04:40am Link  |  Quote  |  Print  |  Notify Moderator
I built a wire mesh tray under the 2nd front section and between the frame rails so I can carry the blue tote, firewood, chairs, etc. it is about 60"x60"x12" and hinges down to load and up to travel totally out of the way. Lots of room and no lower that the sided of the camper. I have room for another the same size in the rear section, but have never built one there. If you park in a spot where you must put the hitch on the ground to level, make sure you unload first! This could be built as a slide-out joey-bed if you had more motivation.
http://niceley.com/nomad/nomad.htm
Bduece
Massachusetts
Posted: 05/06/08 05:22am Link  |  Quote  |  Print  |  Notify Moderator
Niceley, I like that storage area. Gives me another reason to buy a welder. I'll add it to the list.
Bill
Bill
2006 Dodge Ram QCSB 4x4 hemi
05 Forest River Cherokee 28A+
