RV.Net Open Roads Forum: Travel Trailers: Scissor Jacks needing cleaned and lubed
 > Scissor Jacks needing cleaned and lubed
kearlms
Rexburg, ID
Posted: 05/02/08 09:15am Link  |  Quote  |  Print  |  Notify Moderator
What is the best grease or grease-less lube to put on the scissor jacks under the TT. I need to clean them up and grease them but dont know what to use to keep them working. thanks.
4Kings
NE Missouri
Posted: 05/02/08 09:21am Link  |  Quote  |  Print  |  Notify Moderator
I would just clean them up with a little brake cleaner then use either a dry graphite or silicone spray. I would stay away from grease as it will attract dirt.
2003 Chevrolet 2500HD, CC, SB, 6L, 4.10, Auto, 4x4
2005 Wildcat 27BHWB, RBW 15K, Prodigy, TTT Mirrors
GHarper
New Hampshire
Posted: 05/02/08 09:39am Link  |  Quote  |  Print  |  Notify Moderator
I loke to use spray motocycle chain lube. It works on the atv's and dirtbikes.
1994 Suburban 3/4 ton +
2008 Crossroads Zinger ZT29DB
Dixonmatco
Santa Rosa, California
Posted: 05/02/08 09:54am Link  |  Quote  |  Print  |  Notify Moderator
An excellent answer! This stuff is designed to not evaporate like WD40, so it will last a long time and is also formulated to avoid attracting dirt.
2000 Chevy Silverado 1500
2005 Komfort Trailblazer T23S
Honda EU2000I
planter8
Utica, MI
Posted: 05/02/08 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
I use gun oil, specifically Rem-oil. It is thin and does not leave a greasy residue. It has my jacks operating smooth as silk.
Planter8
Sunset Trail ST30BH
Ford Econoline E-150 wagon 5.4L V8 3.55 axle
Equal-I-zer hitch
rlc323
Illinois
Posted: 05/02/08 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
Second that for Rem-Oil. It contains a teflon lubricant and provides corrosion protection. Cleans and does not attract grit. Not cheap but good stuff.
2002 Chevrolet Avalanche 1500 Z-71
2002 Trail Lite 8261
Hornet28BHDS
Parker, PA
Posted: 05/02/08 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
I hit them with some WD-40.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
ditchdoc1017
Jasper,Al
Posted: 05/02/08 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
I do the same thing.
TV 2007 Tundra 5.7 MC 4x4
2007 GulfStream BH
07 Tundra MC 5.7 4x4
Me,DW,2 Boys 8,13 girl 6.
Roadtrip Kids start packing
Chuck&Gail
In the Colorado Mountains
Posted: 05/02/08 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
I use WD40. Works fine for me. Don't care if it shouldn't, it does.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
Dixonmatco
Posted: 05/03/08 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Of course WD 40 works.. It has a form of lubricant as a part of it's chemical composition. It just won't last as long as some of the other suggestions. You just have to apply it more often to achieve the same results.
Any lubrication is better than none. (but grease does attract a lot of dirt)
