Frosty's Mom
Idaho
absolutely love our minnie winnie (2003) and while i haven't found a big problem with heat at the floorboard while driving (driver or passenger side) as i've read on this forum, we do seem to have a 5" round vent that evacuates HOT air from under the passenger bench at the table that seems to have no way to be closed off in the summer while we're trying to run the air conditioner. can't seem to reroute the air or shut it off. impossible to cool the coach while driving and quickly reached over 82 degrees last weekend. while it would seem more expedient to run the coach air conditioner than the chassis a/c, it makes no sense to do either if we can't shut off that hot air.
what's up with that?
wee3-gin, clyde & the bichon frise
2003 Minnie Winnie 30V - "The Frosty Hauler"
May the Angels guide your wheels and ride on your shoulder.
tatest
Oklahoma
That sounds as if your furnace is running when you turn the A/C on. There may be a problem with the thermostat, if it controls both.
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
jauguston
Bellingham, WA
If you are having this issue when driving and the AC is the dash air it could be as Tom said and your furnace thermostat is set for heat and is on.
Jim
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
275 RV injectors
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
Frosty's Mom
Idaho
thanks, fellas.......but that's one of the first things we were told about--not trying to have the coach furnace on while driving. (tech said it'd just blow out anyway.) however, we usually use the heat pump unless it's terribly cold (20's)(then have to switch to LP)....so we couldn't have forgotten to turn the furnace off as the thermostat was switched to a/c (thermostat is one that does a/c [left][off]--gas [heat-right]--electric [heat-most right]).....actually it feels like heat off the engine, but can't imagine that is ducted to the coach.
CISCO8325
Peoria,az.
take a picture of it ,I'm comfuse of what your saying.is it the coach a/c or the chassis a/c your concern about the heat is coming from..LOL
buchrob
Stanstead QC
That size vent has to be supplied by the furnace, not the vehicle A/C.
Just about any RV dealer should be able to supply you with a directional/closeable version of this vent for under $20. Make sure the furnace is off as well as the vent outlet and you should be good to go for just a few bucks in parts and labor.
'99 Glendale Royal Expedition 24' Class C
2003 Subaru WRX wagon as toad.
kgmz
Portland, OR and Eatonville, WA
Do you have a rotary knob on the dash to the left of the steering wheel that has 4 positions??
Usually this knob is close to the battery Aux momentary rocker switch.
If you do your Winnebago has the MotorAid option.
Also if you have this option have you noticed that the water in the hot water tank is hot after a long drive even though you did not turn on the water heater.
The MotorAid option is hot water lines from the radiator run to the hot water tank and to a heater for the coach. The knob on the dash is a 3 speed fan switch with a off position. You should depending on the floor plan of your coach have a vent under or near to the dinette and another in the kitchen or somewhere in the hallway between the kitchen and bath. These vents look like the normal rectangular house vents and not like the normal round RV furnace and AC vents.
1998 29' Itasca Sundancer pulling a 2002 Interstate West 27' All-Sport, 10,400 GVWR with Yamaha Mountain Viper's inside.
2001 Suburban 2500 LT,8.1,4.10
2001 2500HD Crewcab Longbox LT,8.1,4.10
kgmz
Just re-read your post and I see you said round vent.
Now if your RV is not a basement model then it may have round vents with the MotorAid option.
The rectangular vents are in basement models since the ductwork runs under the floor just like in a house, and the vents are in the floor or cabinet toe kick but still coming from under the floor
Frosty's Mom
Idaho
kgmz wrote: Do you have a rotary knob on the dash to the left of the steering wheel that has 4 positions??
oh my gosh, kgmz! you nailed it! sheesh! not an option pointed out by the selling dealer or anything i've noticed in the papers/booklets/pamphlets we got with the rig. i took the camera out to get a photo of the round vent (yes, we do have a pretty good basement with a winter package), but first hopped into the cab to check for the knob, which i was pretty sure wasn't there. there it was! and when i went to turn it--it turned left 3 positions to off. HA...it'd been running on high every time we've had the rig out. and yes, we'd noticed the convenience with the hot water heater. it don't take much. the vent is indeed right under the dinette bench and can really put out copious amounts of heat.....keeps the coach downright comfy even in march when we were out in some freezing temps....but then those temps turned warm.
thank you, all, so much and especially, kgmz, appreciate your dead on diagnosis. gees, i love this forum and that minnie winnie. it has had so many thoughtful touches added, we obviously haven't found them all yet.
