RV.Net Open Roads Forum: Technology Corner: Sprint Card
 > Sprint Card
ngreen
Neosho, MO
Posted: 05/02/08 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Sprint Air card - about 50% of bars on connection - the only internet connection I can get is rv.net - could be worse - but does that make sense - wondering how I can get more so I can check the weather out here in tornado alley - already saw one today and one is enough
hershey
Albuquerque,(fulltime) NM, USA
Posted: 05/02/08 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
That doesn't even make any sense. If you can pull up the RV.net URL you should be able to pull up any other URL. What happens when you try a different URL?
hershey - albuquerque, nm
Someday Finally Got Here
NASCAR 20 - - 99
ngreen
Neosho, MO
Posted: 05/02/08 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
Nothing happens - it never connects and I evidently get cannot find server but yet I can play on here - must be cause it is most visted website!
judy&frank
Seattle, WA
Posted: 05/02/08 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
Contact the tech people at 3GStore.com. They have an antenna that pulls in great signal for us with a Sprint broadband account with a 727 modem.
Judy and Frank and Missy (purr-person)
2001 Ford F-250 4X4 Powerstroke 7.3L Extended Cab Long Bed
Crossroads Cruiser 28RL double slide 5th wheel
cctv
Minneapolis Minnesota
Posted: 05/02/08 10:30pm Link  |  Quote  |  Print  |  Notify Moderator
When your at rv.net enter dslreports.com into the address bar then click enter. There is no reason you should not be able to go to another site if you can get to rv.net (although it may load slower if it contains a lot of graphics) and it is usually the other way around for me. In fact I have stop using the rv.net portal and instead have started using the trailerlife.com portal, it works far better and you get the same forums that you get with rv.net
2oldman
WA
Posted: 05/02/08 11:25pm Link  |  Quote  |  Print  |  Notify Moderator
No it doesn't make sense.
SCVJeff
Santa Clarita, CA.
Posted: 05/03/08 02:31am Link  |  Quote  |  Print  |  Notify Moderator
I'm with the rest: It makes no sense at all as RV.net ranks at the top of my connect failures, and while reasonably fast when it works, there are thousands that are faster.
Back to the basics.. Try YAHOO.com and see what you get, the site should pop up almost immediately. Yahoo seems to be the defacto IT test site for web connectibility.
Jeff - WA6EQU
cooper841
Maryland
Posted: 05/03/08 04:49am Link  |  Quote  |  Print  |  Notify Moderator
I got that sprint card.sometimes it will take a few minutes to get connected but other than that it works in the coach and outside.
Dana & Julie Cooper
Kozy & Pierre
2007 Fleetwood Fiesta LX 31M
6'x12' enclosed Trailer
Harley & Suzuki Motorcycles
 > Sprint Card
