RV.Net Open Roads Forum: Class A Motorhomes: 1997 Newmar Mountian Aire?
 > 1997 Newmar Mountian Aire?
TDInewguy
Minneapolis, MN
Posted: 05/03/08 12:43am Link  |  Quote  |  Print  |  Notify Moderator
I found one locally to me at a very nice price. It's got the following:
66K miles
Independent Front Suspension
Diesel generator
I have seen a few photo's - but with a 1997 - is there anything to look out for? The seller is the original owner.
Thank you!!
SSSStefan
2006 Chev 2500HD - Crew Cab D/A
2005 VW Passat TDI wagon - tow vehicle for the pup!
2005 Fleetwood Allegiance
The most important thing you will ever do - www.claybe.com
Bumpyroad
Virginia
Posted: 05/03/08 04:20am Link  |  Quote  |  Print  |  Notify Moderator
I believe in 97 they were still using rubber roofs on them.
bumpy
SemperFiCop
Posted: 05/03/08 08:04am Link  |  Quote  |  Print  |  Notify Moderator
Spartan or Freightliner Chassis?
webhannet
Southern Coastal Maine
Posted: 05/03/08 08:42am Link  |  Quote  |  Print  |  Notify Moderator
Wouldn't an independent front suspension mean it had to be Spartan?
SemperFiCop
Posted: 05/03/08 08:50am Link  |  Quote  |  Print  |  Notify Moderator
Do you know the Answer
or
are You asking?
TDInewguy
Minneapolis, MN
Posted: 05/03/08 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Spartan Chassis
Cummins 325HP engine
I got an e-mail back from the owner - he is the original owner... he has replaced the water heater, furnace, microwave... the front TV just died, but not replaced yet.
I am curious about a few things - i read a while back that there were some problems with ball joints on the front suspension?
The seller said fiberglass roof, and it did have a leak, but it was caulking at a seam that has been fixed.
The asking price is just under $50,000 - which is lower than NADA low retail for this RV...
I'm just wondering if there are other things to watch out for specifically on this make/model.
Thank you!
Bumpyroad
Virginia
Posted: 05/03/08 10:11am Link  |  Quote  |  Print  |  Notify Moderator
of that vintage I would "guess" that the fiberglass roof is the old 3/4 or 5 piece one that they used way back when. maybe that is why a seam leaked?
bumpy
bsinmich
Holland, MI
Posted: 05/03/08 11:01am Link  |  Quote  |  Print  |  Notify Moderator
If everything looks good you can't go wrong with most Newmar's if they have been taken care of. They are top notch and they are the ones that invented the slide back in 1990.
2003 Newmar Mountain Aire, Workhorse W22, & 2002 PT Cruiser w/Remco lube pump, Falcon 5250, & US Gear Unified Tow Brake
Bumpyroad
Virginia
Posted: 05/03/08 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
they may have invented the drop down flat floor slide but I think slides preceded them. that slide that when pulled in makes the hallway higher on one side than the other and a bear to walk on.
bumpy
Deen
Vancouver, WA
Posted: 05/03/08 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
66K miles
Diesel generator
Thank you!!
Check front axle weight and tire capacity. Along about then there were front axle overloading problems on the Spartan chassis, Newmar went up a size or two under warranty. Could have 275/80 tires although some got 275/70's.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'97 Grand Cherokee/4 down
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
