Cessna 182
owensboro ky
My microwave will not operate. Light comes on but will not heat up. Is this a throw away or can it be fixed?
tks
Have a good one
Jim
99 Holiday Rambler Vacationeer
95 Escort Toad
Road Runners
Tampa Bay, Florida
You unit can probably be fixed. Since it is most likely a smaller unit you can be take it out and cart it to the repair man. Saves a lot if you don't have to pay the guy to come to you. You can get an estimate on the repair and decide if you want to repair or replace. Frankly, microwaves are not all that expensive.
'05' F-250 Power Stroke
'00' 30' Cameo Fifth Wheel
Wherever I happen to park
Throw away of fixed.. If you have to ask throw away
I say this because fixing it costs around 100/hr one hr minimum unless you can do the work
Now if it was me.. There are basically five parts that could be bad
Switch (I have seen bad door switches)
Diode (I have replaced diodes)
Magnatron (Throw it away)
Transformer (Throw it away)
Control board or timer (Depends, some you toss, some you fix)
Gale Hawkins
Murray, KY
Ours died at the office and I was impressed with what they came in with for about $50. Our first one 28 years ago was about $800 and with about the same features.
samsontdog
Sac. Ca summer, Yuma Az winter
First thing I would do is take the case off. Check to see if there is a fuse blown. They are not just a regular fuse. The last one I replaced was about $5.00
samsontdog
wtravlr1
Palm Harbor, Flordia, and Geneva-on-the-lake, Ohio
I replaced mine with one from Wally World. Fit within the opening just fine for less than $80.00.
2007 Forest River Sierra 31fkd (37') dual slides
chevy suburban 2003 2500-8.1 L.4.10's
prodogy/reese dual cam
rollgard springs
Fulltiming it since 2004. My only home.
My Homepage and Rv pics press here
Wingnusa
Scott and Brenda Albuquerque, NM
We just went thru this a few months ago. It was going to cost more to fix than replace. Go to Lowes/Home Depot or any other home store and look for scratch and dents. We got a real nice one with a scratch on the side that you can't see anyway.....
Scott and Brenda Schnelle
Olivia and Jasmine, Mini Schnauzers
2006 KZ Escalade 36CKB
2006 GMC 3500 D/A(LLY), CC, LB
Fulltimer Class of '06
Lifetime Good Sam's members
Lifetime NRA member
USCCA Member
Amateur Treasure Hunter
Amateur Banjo Player
