AISURFFISH
BERLIN MARYLAND
i am not to impressed with the water preasure of the waterpump.
is there an adjustment for preasure?
can one put a larger pump in to get more preasure.
any sugestions
i have the factory pump for my lance 881 2005
2004 F350 V-10 GAS CREW CAB SHORT BED BLACK
THE LANCE MAX 881 TORK-LIFT FAST GUNS AND SUPER HITCH
COOLER RACK OFF THE FRONT ALWAYS FULL OF BEER
A.M.S.A. MEMBERS HIM 1025/HER 1026/JUNIOR 93
MID ATLANTIC TRUCK CAMPER RALLY INFORMATION PAGE
fredderf
lanc pa
just a quick thought ... try cleaning the filter .it helped with ours
ford '01 250, 4x4, 5.3, sb, cc
ranchos , helig rear swaybar,air bags
'05 lance 845
'go fish....'
WX2G
Central Florida
While you are at it, clean the screens in the faucets.
lv2rom
Kansas City, Missouri
Cleaning everything, everywhere, won't change pressure at all...may help improve flow, but not pressure. Most factory pumps are low flow pumps (2.0 to 2.3 gals min)and have a built in fixed pressure switch. Some have a small stainless steel screw on the head of the pump that can adjust cut in/cut out pressure points? If yours has this you might be able to raise the pressure a little bit.
Now to flow rate...you could increase the gallon flow per min with a bigger pump...say 3.0 or even a variable up to 5.7. The limitation however is likely the size of the water lines themselves...they can only flow a certain amount of fluid. If cleaning everything out doesn't improve your flow and larger pump may be in order....Brian
2005 F350 Dually -AFE air/MRSP exhaust/Bags/Bilsteins/Energy Susp.
2002 Hitchhiker Fiver 29.5 RLBG - Moryde Pin/Gas shocks/Michelin XPS Ribs
1996 Layton Fiver 21ft. Totally reconditioned..Love it!!
AISURFFISH
BERLIN MARYLAND
fredderf wrote: just a quick thought ... try cleaning the filter .it helped with ours
filter???
huh"\???
never ever knew it had one...
may be in need of a lil cleaning
thanks fred. hey i took a break from the beach and hit a few banks around the chesapeake. did a lil boondocking.
deale island
rumbly
then over to stockton out behind AI
not much luck but a welcome change of pace...
AISURFFISH
BERLIN MARYLAND
lv2rom wrote: Cleaning everything, everywhere, won't change pressure at all...may help improve flow, but not pressure. Most factory pumps are low flow pumps (2.0 to 2.3 gals min)and have a built in fixed pressure switch. Some have a small stainless steel screw on the head of the pump that can adjust cut in/cut out pressure points? If yours has this you might be able to raise the pressure a little bit.
when i am on "city" water hookup there is plenty of preasure. i think maybee my pump is just hurting a little.
fredderf
lanc pa
AISURFFISH wrote: fredderf wrote: just a quick thought ... try cleaning the filter .it helped with ours
filter???
huh"\???
deale island
rumbly
ours got real bad on a trip to lookout ..
on the top of the pump , there is a cover that unscrews . a screen type of filter is under it . if that is the same pump that is on our 845 ..
(disclaimer to prevent being flamed )
one of the few times we 'hooked' up to the water at a campground , i noticed a pressure difference too ...
just 2 different critters
Reddog1
El Dorado, CA (above the fog & below the snow)
Most, but not all, pumps are adjustable. I replaced the old pump in my TC with a SHURflo Whisper King Demand Fresh Water Pump. It is adjustable up to 30 PSI.
I also added an Accumulator-Tank, similar to this one Accumulator-Tank. I bought my tank from a Home Builder store, for less than $40. I think both are great, and recommend the upgrade.
I also drilled out the orfice, in the ket faucet.
Wayne
blog.rv.net - Your daily guide to the Open Road.
Reddog1 Photos
96 Dodge (DSL), 2500 (6200#)
88 Bigfoot @ 1500# per decal, Stable Lift (w/remote), 130 watts solar, 100 amp AGM, Polar Cub A/C, EU2000i Honda Gen.
Toad: 91 Zuke
Zig
Indiana
Another thing to note is the restricter washers they install in some lines. The shower hose in ours had a hole about the size of the lead in a pencil. Our kitchen sink had one similar in it too I believe. maybe they install those to save water?
Reddog1
Zig wrote: Another thing to note is the restricter washers they install in some lines. The shower hose in ours had a hole about the size of the lead in a pencil. Our kitchen sink had one similar in it too I believe. maybe they install those to save water?
These are the ones I drilled out to a larger diameter.
Wayne
