RV.Net Open Roads Forum: Technology Corner: DirecTV or Dish network
 > DirecTV or Dish network
tadpole2
Alba, Tx
Posted: 05/03/08 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
When ordering our new 5er we decided to go with a portable satellite dish. Now it is time to make up our mind as to DirecTV or Dish. We have DirecTV at home, but we are going fulltime and don't know which one is the best for the road. The man in town installs either one. He told us that with DirecTV you have to run 2 wires from the satellite if you are going to have tv in living and bedroom. Dish only has 1 wire. We want to be able to get CBS, NBC, Fox and sport channels all over the US. We also have a HD TV. Please help
2oldman
WA
Posted: 05/03/08 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
Dish v direcTV 1
Dish v direcTV 2
Dish v direcTV 3
Dish network search
Dish in Rv
Dish - add receiver
Dish network search with tripod
NC Hauler
Asheville NC
Posted: 05/03/08 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
I'm too lazy to look all that up, I've had both, but changed from Dish to Direct some years back because camping in the mountains, I always had a bit of a problem with Dish because the azimuth is lower then Direct tv...with direct, you are looking higher in the sky for the satellite, thus, it's easier to "shoot" over the mountains and some trees with Direct then it is with Dish..Just my opinion and the reason I switced from Dish to Direct. Since then, I've had little to no trouble picking up a signal to watch TV with.
Jim & Kathy
2007.5 Chevrolet K3500DRW/CC/LB/LMM/D/A LTZ, Prodigy,Reese 20K hitch.
2006 HR Presidential Suite 37RLQ (4 slides).
2007 Mitsubishi Outlander XLS 4X4
Boxers: Sheba, 13...Buddy..1 yr.
USAF 71-75 Nam Vet
JEBar
Willow Springs, NC
Posted: 05/03/08 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
we've been using Direct for several years and have been well pleased ... all that is required to get your local channels (where ever you are) is to call them and tell them to set your local channels to your location ... no issues to date and we've been ocean to ocean and border to border
Jim
'07 Freightliner Sportchassis
'06 SunnyBrook 34BWKS
2oldman
WA
Posted: 05/03/08 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
I hope the OP isn't. Took a while to compile all that good information.
CardinalCamper
Wichita Kansas
Posted: 05/03/08 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Have been with Dish Network for 6 yrs. Happy with them and the only time I have trouble locking both 110 and 119 is when around a bunch of trees.
Charles & Dawn
2005 Cardinal 35 CKT LX
2000 F-250 PSD 7.3 4x4 CC,5" Dual Exhaust, Hypertech Power Programmer III, Firestone Ride-Rite Airbags, Air Safe 25K Air Ride Hitch,RoadRunner 50cc scooter
Basset Hound (Shorty)
Dutch & Di
Livingston, TX
Posted: 05/03/08 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
We've had DISH for the 12 years we've been full timing. Overall have been very satisfied. Have heard both positive and negative about both so you have a hard decision ahead of you. One thing about it, with all the incentives out there, if you don't like one, just cancel after your contract is up and try the other. Good Luck, Diana
1996 1 ton Dodge Dually , Jordan Ultima Brake Controller, Mor/Ryde Suspension Rear Springs, Air Bags, Tailgate Easylift
1996 Tripple Slide Carriage, Mor/Ryde Suspension, Kodiak Disc Brakes, Power Plus Automatic Leveling System, Plug It Right Stabilizers
carlson
Moultonborough, NH
Posted: 05/03/08 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
DIRECT TV, hands down.
What ever system you have you will need a seperate cable feed.
If you want a HD DVD reciever it will require 2 cables.
If you want to easly get east and west coast feed, again direct is the way to go.
Easy to get your RV waiver, just need a copy of your trailer registration and fill out the form and mail or fax it in.
Good luck
E. Sven and Pat Carlson
Full Timers
Meredith, NH & Yuma, AZ
2005 Montana 3400RL
2007 Crew Cab Frieghtliner, M2 106, Mountain Masters body
66stang351
Willamette Valley
Posted: 05/03/08 10:56pm Link  |  Quote  |  Print  |  Notify Moderator
As for your one wire scenario, DIRECTV does have a solution to that now as well. It isn't cheap, but it can support up to 8 tuners on a single wire. It is called a SWM(Single Wire Multiswitch). To get one you will have to go to an online retailer like solidsignal.com and pay somewhere in the vicinity of $300. The SWM can be mounted at the dish then a single cable goes inside to the power supply. From there high frequency splitters do the trick.
BTW, I carry around 2 HDDVRs and another HD receiver with only one wire coming into my trailer for DIRECTV.
sirdrakejr
Las Vegas, Nevada
Posted: 05/03/08 11:25pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from 5th wheels to technology corner.
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
