Don Paul
Fowlerville,Mi 48836
I am having my hitch installed next week in my new 2500 Chevy, replaces the 1500 GMC, my question is since the truck sits higher am I going to have to have the axles flipped or will they be able to make the movements on the front pin to adjust to the new high. Just trying to get a heads up on how much this is going to set me back.
Thanks
2003 COUGER 278EFS
2007 CHEVY 2500 4X4 CREW CAB
TXiceman
(Near) Houston,TX
You want to have at least 6" clearance between the bed rails and the trailer...with the trailer setting close to level. If the trailer is nose down, you will tend to over load the front axle and it it is nose high you will tend to overload the rear axle.
So if the trailer pin and the hitch can not be set to give you the 6" clearance and a level trailer, you may have to place the axles below the springs or you may have adjustable jake plates.
Ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
Vulcaneer
Northern New England
You might already have your axles mounted under your spring mounts. Many 5W's come that way these days. Since they are usually towed by class 2 or 3 LDT's trucks. If the axles do needs to flipped could set you back anywhere from $300 to $500. Get a few quotes from shops in your area.
But before you do anything, hook it up to see what you may need done.
2006 F350 V10 4X4 SC SB SRW 4.30 22,500 GCWR
Keystone Sprinter 33'9" 12,500 GVWR
Pullrite Super Glide 18K
Super Duty, Super Cab, SuperGlide
SEE RV.net Classified for Vette Description
gm seller
holland ny
hook it up first and check it I pull with a 2500 HD GMC should be the same height as yours and I have 8 inches of clearance and I didn't have to do any adjustments. The 5er sits perfectly level.
2006 GMC Sierra SLT 2500HD crew cab 8.1 with 6 speed allison
2007 Keystone Laredo 32rs
Myself, Darling wife Lisa
Laura 16,Sara 13
2 Jack Russell's
Jack & Rusty
Cheddarhead
Northern Wisconsin
I switched from a 95 1500 to an 06 2500 and did not have to change anything.
2006 Chevy 2500HD EC/SB 4x4 Duramax/Allison
05 Jayco "Jayflight" 285RLS
Some of our trip Pics
outdoorsman2007
In the Woods - Somewhere!
There is probably some up and down adjustment on the fifth wheel's pinbox and the hitch probably has some up and down adjustment also. Like someone mentioned above, always maintain at least 6 inches between the truck rails and underside of the fifth wheel. Also make sure the fifth wheel rides level when attached to the truck.
goin2themountains
Aztec, NM
Hook up first and take a look, then see what can be adusted around hitch or pin. I am running 285's on my HD2500 and 5er suspension is stock. I have about 8 inches of clearance while the trailer is almost dead on level. Good luck, and have fun.
Puller: '04 HD2500 4x4 SB,EC Duramax/Allison. Airaid intake, 4in. exhaust turbo back, ORU leveler.
Pullee: '02 Keystone Cougar 276EFS Reese 16k w/ slider.
(map is for current 5er only)
Lisa125
Northern CA
We have an 08 Chevy 2500 4wd and we had to lower the pin box on the trailer to the lowest notch to get enough clearance over the bed rails. We have barely enough room at that setting. We are using a pullrite superglide so there is no hitch adjustment and the axles are already under the springs. We do not sit level either. We ride a bit nose high.
08 2500HD diesel/cc/4x4/sb/superglide w/superrails
08 Durango 325bh
1 22 month daughter
2 bratty border terriers Sam and Jenny
5th amendment
yale mi
hpoefully you have some adjustment at the pin if you need to
34' liberty
07 2500 dodge 5.7
six speed manual 3:89 rear end
Dennis Bham
Alabama
FWIW, you can not compare pre 2007 Chevy HD trucks with 2007-2008 models ... The new body style has side rails approx 2" taller than the Classic models. ie, the bed is not higher off the ground, but the box is deeper ...
First step like others have said is to hook it up and see what you got. On my new Cougar I replaced my trailer wheels with 16" and dropped the pinbox 1" to get 6" clearance and a level trailer.
Dennis
'08 Chevy 2500HD Duramax 4x4, Crew Cab, Std Bed e/w 18K Superglide
'08 Cougar 292RKS, e/w 16" Sendel wheels & BFG Commercial TA tires
PressurePro TPMS
