RV.Net Open Roads Forum: Fifth-Wheels: slide out awning
 > slide out awning
marti1751
Michigan
Posted: 05/03/08 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
We have a new awning over our main slide out. My question is this, when it rains we have water pool in the middle of the awning. If its a hard rain, it will almost sag down and touch the top of the slide. We were told this is normal and not to worry.. Has anyone else had this problem.
Thanks
PAUL3500HD
N.W.Ohio
Posted: 05/03/08 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
Thats Normal
Dont worry about it
When you put your slide in it will roll off
Enjoy
2006 3500 Silverado CC D/A Dually 4x4 LT3
Summit White
15K REESE
2005 K-Z Sportsmen 3052px2 Limited
Prodigy
MY PICTURES
More Pic's
3500 DUALLY CLUB MEMBER # 128
wtravlr1
Palm Harbor, Flordia, and Geneva-on-the-lake, Ohio
Posted: 05/03/08 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
some use a small beach type ball underneath to "dome" the awning. I don't do this, just let it roll off as well.
2007 Forest River Sierra 31fkd (37') dual slides
chevy suburban 2003 2500-8.1 L.4.10's
prodogy/reese dual cam
rollgard springs
Fulltiming it since 2004. My only home.
My Homepage and Rv pics press here
Vulcaneer
Northern New England
Not a problem. Until you close your slides and dump all that water on your wife as she is standing on your door steps. Then it's a problem.
2006 F350 V10 4X4 SC SB SRW 4.30 22,500 GCWR
Keystone Sprinter 33'9" 12,500 GVWR
Pullrite Super Glide 18K
Super Duty, Super Cab, SuperGlide
SEE RV.net Classified for Vette Description
Ruth & Edward
Indiana
Posted: 05/03/08 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
We’ve had rainwater pool in our slide toppers (awnings). As others have said, it is normal. It doesn’t likely cause any harm, but I wanted to prevent the pooling so that, when breaking camp, I’d stand a better chance of retracting dry slide toppers (awnings).
There are two inexpensive ways to eliminate the pooling - beach balls (already mentioned) or swim noodles – depending on how much height you have between the roof of your slide-out and the underside of the awning. In my case, the slide toppers were added by the dealer, and mounted lower on the side of the trailer than if they had been installed as part of the original (assembly line) build. Because of this lower mounting, beach balls were too big for my use.
So, last week, I went to Wal-Mart and bought four 5ft swim noodles; one for the bedroom slide; three for the main slide (I’ll cut these three to the right total length, then string them together with drapery cord). Wal-Mart’s noodles are available in two diameters; 3.5” ($3.88 each), and 2.5” ($1.50 each). I bought the 3.5” diameter size.
Yesterday, I went out to the storage lot where I keep my fiver - to do a test fit of my new “anti-pooling devices”. I’m pleased to report that the 3.5” noodles were the perfect size for my application.
It appears I’ve solved my pooling problem. As a side benefit, since the noodles take up the slack in the slide toppers, I should have much less flapping in the breeze.
2006 Ford F350 V10 2WD SRW SuperCab Short Bed
2005 Sunnybrook Titan 30RKFS Fifth Wheel
ReneeG
Meridian, Idaho
Posted: 05/03/08 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
We had a Colorado Carefree awning installed on our slideout after we bought our TT. The manual says to periodically retract the slideout during rain to dump the build up, pooled water. We do this and it seems to work. What I REALLY don't like is the noise they make during windy weather. If it's really, I mean REALLY windy, we will bring our slide out in to avoid any possible tearing. It probably won't but better to be safe than sorry.
2006 282TS 32' Komfort
1999 Ford F250 4x4 XLT SD Triton V10 with Tow Package
Prodigy Brake Control
Magnaflow Cat Back Exhaust, FIPK, and TransGo Shift Kit
Hensley Arrow
Dave and Renee plus Champ, Molly (in spirit), Missy and now Maggie Along for the Ride!
tvman44
Southwest Louisiana
Posted: 05/03/08 10:49pm Link  |  Quote  |  Print  |  Notify Moderator
Just be sure no one is standing near the slide when you bring it in with a pool of water on it.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
 > slide out awning
