RV.Net Open Roads Forum: is there a better way to open screen door?
 > is there a better way to open screen door?
ryanallie1
Magalia, Calif
Posted: 05/04/08 09:17am Link  |  Quote  |  Print  |  Notify Moderator
tls5150 wrote:
The issue with the slide is its a pain!! Always comes off the track just like everyone's.. I did see the Camco idea but could not see how the outer door could be opened from the inside with the new latch installed.
Hi All.
I have never had a slider on my screen doors ever come off, or come out of the track,in over 40+ years of RV'ing. Buy a new slider, and when you re-screen your screen door, make the slider fit tighter. Most replacement Slider are normally a little bigger, and need to be trimmed down some. You can also re-adjust the botton track, if it fits to lose. You can also add a thin layer of felt, to take up the slack in your track. Simple fixes for simple problems. Good Luck. Happy Camping. Dan & Jill
1997 Ford F-250, H.D. Extended-Cab, Short Bed, 7.3 PSD, K&N Air Filter, 5000 lbs air bags w/on board compressor w/guage, SuperChips Tuner/Programer. 1996 Nash 24fter 5er, 15K "Lil" Rocker Hitch w/BedSaver, Twin EU2000i Gen's W/Kit. Nam-Vet, 33 Months.
portscanner
Georgia
Posted: 05/04/08 09:26am Link  |  Quote  |  Print  |  Notify Moderator
I recently saw a post where someone removed the little plastic latch and put in friction catches. Then when you exit, you can just push the screen door open. Magnetic catches were used to hold screen door open against the solid door. If I can find the post, I will put a link here.
PackerBacker
Montreal, Quebec,Canada
Posted: 05/04/08 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Belgique wrote:
PackerBacker wrote:
What's the issue with just sliding the plastic door?
Our cat can open it quicker than we can
Never thought of that.
PackerBacker
Posted: 05/04/08 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
Our's never comes off.
Mike Schriber
San Diego, CA
Posted: 05/04/08 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
Mine comes off the track all the time.
I got sick of the slider so I made a variation of a mod I saw here.
I didn't want the actuator rod moving with the slider like others I've seen so I changed the design to go through the fixed plastic on the side.
It works great!
Mike
2005 Chevrolet Suburban K2500 LT (8.1 liter with 4.10 gears)
2004 Starcraft Homestead 29BHS (16,000 pounds combined)
Twin Honda EU2000i Generators - 12' Porta-Bote
Prodigy / Putnam XDR / Equal-i-zer
SoCal Family Campers
pete42
Jamestown, Ohio
Posted: 05/04/08 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
TLS5150 the wire is left long enough to allow the slide to open.
Mike nice addition.
Mine does go through the sliding part.
I drilled the hole at an angle ran a bucket pail wire nice and heavy I left the push wire long enough the slide opens with out any problem.
I topped my wire with an Insulin needle cover bright orange it works like a charm.
bamcote
Freedom NH to Crossville TN
Posted: 05/05/08 12:13am Link  |  Quote  |  Print  |  Notify Moderator
easy screen door opener
I used the straight bottom bar of a wire coat hanger, wire cutters, electric drill and the cork out of a wine bottle. Took all of 15 minutes to do. Absolutely love it.
DH, DW and 2 chats-Butt and Mocha the Siamese sisters
Molly the Maine Coon kitten
Mina the rescue mutt
2008 Fleetwood Bounder 36Z
1fastdad
mo.
Posted: 05/05/08 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Mike I made mine similar to yours but I bent mine 90 degrees at the handle and came straight up threw the slide stop. I just put a rubber automotive vacuum cap over the end of it so no one would try to grab it to close the door. By bending it 90 degrees it doesn't interfere with the outer door latch.
kraushad
Eastern Panhandle, WV
Posted: 05/05/08 07:41am Link  |  Quote  |  Print  |  Notify Moderator
A side issue regarding the slider coming out - I just replaced the slider and the piece next to it with clear plexiglass (another idea I read on here) adds more light into the camper, more view out of the camper, and is more sturdy and doesn't fall out. This mod along with the removable plexiglass upper and lower pieces over the screen that many people use allow us full visibility even if we are camping in weather that requires the furnace or AC.
In the clear plexiglass just drill a small hole and use two cabinets knobs on either side of a short bolt with the head cutoff and it works great for a handle.
I tried the push handle through the slider once, and still keep it with us, but we don't use it that much. It seems to get in the way, and the little one can find it too easily
* This post was edited 05/05/08 07:55am by kraushad *
Dirk
Myself (34), my Wife(32), and "The Boy"(3)
06 GMC Sierra 1500 Crew Cab, 5.3L V8, 3.42rear
05 30QBSS Trail-Cruiser, Prodigy BC, Reese Dual Cam W/D
