RV.Net Open Roads Forum: Fifth-Wheels: Trip'n that little 15 amp fuse
 > Trip'n that little 15 amp fuse
wayne_tw
South Dakota/Georgia
Posted: 05/04/08 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Using Ohm's law:
Ceramic heater 1500 watts divided by 120 volts equals 12.5 amps
Television 375 watts divided by 120 volts equals 3.125 amps
Coffee maker 900 watts divided by 120 volts equals 7.5 amps
Total amps load equals 23.125 amps or 8.125 amps overloading the 15 amp circuit
The circuit breaker is doing its job correctly.
Jack_Diane_Freedom
Toronto Canada
Posted: 05/04/08 07:29am Link  |  Quote  |  Print  |  Notify Moderator
We have much the same problem. On single 15 amp breaker is kitchen outlet (coffee maker, entire entertainment system, and electric fireplace. We have learned the 3 count. If there is 3 things on it will trip the breaker.
tvman44
Southwest Louisiana
Posted: 05/04/08 09:46am Link  |  Quote  |  Print  |  Notify Moderator
Just the heater draws abut 12.5 amps, thats all you can put on a 15 amp breaker.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Sundowner1
Chesapeake, VA
Posted: 05/09/08 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
TV 2 amps
coffee maker 9 amps
ceramic heater 10 amps
You are already over the 15 amps for the breaker.
Sundowner
04 Chevy 2500HD, Duramax, ext cab, short bed, 4X4
08 Fleetwood 325RKTS
