RV.Net Open Roads Forum: Travel Trailers: towing with new Jeep Liberty
 > towing with new Jeep Liberty
Page of 8
hemi231
michigan
Posted: 05/05/08 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
This is a 2008 Jeep Liberty Limited 4x4 with tow package, and under the spec and in the brochure and from the Jeep customer service it has the tow rating of 5,000. We are going to rv dealer tomorrow to have them check hitch or see if they can do something. thanks for all your help.
Agrnbrt
NJ, U.S.A.
Posted: 05/05/08 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
You still don't get it do you. The brochure is crap. The dealer's a lying thief and...It just aint a big enough horse for that carriage.
08 Jayco Eagle Super Lite.
07 Chevrolet 2500HD Classic. Reese 16k hitch & S/C tailgate.
Camping with: 1 Wife(Teri)
4 cats, Trouble(the Stynx),Seamus O'Fuzz(Buddha Kitty),Minx(tailless Buddha Kitty)& Bubba(the Love Sponge)
Oh yeah, one Sig P220 .45 acp.
canoe on top
Denver, CO, US
Posted: 05/05/08 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
Bumpy, I would never go that far. Everybody knows pro rasslin is real.
Hornet28BHDS
Parker, PA
Posted: 05/05/08 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
Keep us updated!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
dodge guy
Chicago, western subs.
Posted: 05/06/08 09:40am Link  |  Quote  |  Print  |  Notify Moderator
When you get there make sure they set you up with a minimum of a Reese Straight Line (Dual Cam). and be sure your there when they do set it up, to be sure it was done right!
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
TXiceman
(Near) Houston,TX
Posted: 05/06/08 10:26am Link  |  Quote  |  Print  |  Notify Moderator
All I can say is...Wish you a lot of luck, because you will need it with that small of a tow vehicle.
Here the Jeep site says 3.73 axle and 3.7L is 3500# MAXIMUM and read the footnotes;Jeep Liberty Site
ken
* This post was edited 05/06/08 10:37am by TXiceman *
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
Vapor_Trails
Yucaipa, CA
Posted: 05/06/08 10:44am Link  |  Quote  |  Print  |  Notify Moderator
One last shot... hemi231, please reconsider. The overwhelming majority of responses to your inquiry said to not tow your 23' TT with your Liberty. Most, if not all of us have some experience with you're truck/trailer set-up (or something very similar) and that's why we all suggested a bigger tow vehicle. We obviously know something about it. Especially the commercial truck drivers that suggested a bigger vehicle. If you won't listen to us Sunday drivers, at least listen to those guys that haul for a living.
Nothing you do to your Liberty will change the facts that you will be overweight, you will be towing above the recommended weight, you will have too short a wheelbase for ideal control and you will be a little underpowered. Regardless, have fun and be safe.
68 Me & DW
93 DD
03 DD
06 F150 Screw 6.5' Bed, 4x4, 5.4, 3.73
04 Tahoe 23RB-GL
Honda EU2000 Parallel Cables
"I hope you like Guinness, Sir. I find it a refreshing substitute for...food." Col. Jack O'Neill, Stargate SG-1.
crappie_fisherman
Fort Wayne, Indiana
Posted: 05/06/08 11:02am Link  |  Quote  |  Print  |  Notify Moderator
Hemi231,
Have you gone thru this STICKY POST at the top of the TOWING forum?
If NOT...you SHOULD.
Sounds like your balance may not be optimal...I'd print this out and TAKE IT to the dealer with you...
Also you need to verify your TONGUE WEIGHT when loaded and compare it to your LOADED trailer weight...ensuring that you have MINIMUM 10% tongue load...12-13% is better though...you may find that you need more to find the stability handle on your setup though...
Also tires...both on TT and TV...ensure you have proper inflation (max on TT would be a good start)...
You are at a WB disadvantage...so you need to ensure that your weights and balance are PERFECT...IMO...
joe.
DH, DW, 2 DD's
2005 Excursion V10 w/4.30's
- Hensley Arrow
- Prodigy
- Hellwig rear sway bar
- RoadMaster Suspension
- Front 2" hitch
- Bilsteins
2007 JayFlight 31BHDS (3 women & 2 slides...it helps! )
Mini & the BEAST
lrak
MA
Posted: 05/06/08 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Actually that site says nothing.
Go here Jeep Liberty Specs
You'll see if you select the Sport the Technical Data shows a 3500lb towing capacity. If you select the Limited the Technical Data shows a 5000lb towing capacity.
Limited 4x4 - GVWR 5675, Curb 4278, Max Tow 5000
Limited 4x2 - GVWR 5600, Curb 4058, Max Tow 5000
Sport 4x4 Manual - GVWR 5600, Curb 4198, Max Tow 3500
Sport 4x4 Auto - GVWR 5600, Curb 4269, Max Tow 3500
Sport 4x2 Manual - GVWR 5600, Curb 3980, Max Tow 3500
Sport 4x4 Auto - GVWR 5600, Curb 3985, Max Tow 3500
I don't see the GCWR for any model of Liberty, but I assume it must be _at least_ curb + max tow + 150lb driver.
i5
Washington State
Posted: 05/06/08 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a tt shadow cruiser 15 foot that was supposed to be able to be pulled by a Jeep Wrangler 6 cly. We drove it the ocean twice and it was s l o w but doable. We canned that idea and bought a Dodge Ram 1500 V8, small v8 model, four door 4x4 off road. Pretty cool, we tow the trailer without knowing it's back there.
The Liberty is too small to safely tow the trailer any great distance. Pick up an old truck, they are going cheap because of the price of gas.
We are going to us our setup for four or five years then look at a Class C if gas isn't $10.00 a gallon.
Good luck, look at camping close to home and travel slow and when traffic is light.
Curt
Page of 8
