Roy&Lynne
Pacific Northwest
if you car is tow'able. Looks like we might need to take our car with us next month, we have a 2002 Hyundai and a 2002 Honda Civic and if I'm going to invest in a tow bar, I need to find out if I can first.
Thanks in advance
Our Road Less Traveled
jenks60
MS. coast
Google "DINGY TOW GUIDE". Read your owner's manual, it should tell you if it can be towed 4 down.
jenks, fulltiming with the DW.
92 Southwind P3(32) 33 ft.
99 Saturn SL2
Rallys attended-TX 2, LA 2, MS 1, AL 2
MA. 1 drop in for visit.
othertonka
Stockton, CA
The 2002 Hyundia can be towed if it has a Manual Transmission.
(Acccent, Elantra Sonota, Tiburan, Sante Fe 2 WD)
Honda has removed there towing approval for all models except the CRV. Look in the owners manual of your Civic, in the index, look for "Towing behind a Motor Home" and see if it is there. If there is a section describing that it can be towed, it will tell you the Shifting procedure for doing it. If it is not there, the answer is probably NO
Motor Home Dinghy Towing Guide
Click on 2002 Dinghy Guide
Othertonka
2004 Southwind 32VS
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Browzin
anywhere
The 2002 Hyundai can be towed with auto transmission if a lube pump is installed. Contact Remco Towing for more info. they make a kit for them.
Roy&Lynne
Pacific Northwest
Lucky for me I have the manual transmission. Gonna check the owners manual now
Again the folks on this board are awesome
Chief45
Porterville, Calif.
With my first Motorhome I towed a Elantra. Good car but I would drag the rear into some gas stations. I still have the receiver you can have for free if you make arrangements to get it.
Wherever I happen to park
You go to www.remcotowing.com (Not clickable by choice) and look at the vehicle application chart
That chart tells if you can tow it or, if you can tow it after modification, and what modifications you need. Or if it's simply not possible.
Harvard
51.37N 114.42W
We towed a 2001 Civic 5 speed manual using Roadmaster hardware for 3 years. Roadmaster is located in Portland OR.
MELM
GA
Moving to Dinghy Towing from Tech Issues.
