james ryan
geismar la.
Be careful when hooking up to 50 amp service.this past friday one of my best friends fried his converter,2tvs,refrigerator,microwave and other items. the cause was when he pluged in and turned on the breaker the neutral was pulled out of the campground plug. we found out that the week before the electrical pedistal was run over by an intoxicated woman on a golf cart. all the rv park person did was stand the box back up and did not check if any damage was done
2003 gmc 3500 dually 2004 prowler regal
Chuck&Gail
In the Colorado Mountains
That is the very reason many of us carry a gadget that checks for that condition, and others, and use it to check CG power BEFORE we plug in.
For 30 amp rig cost is about $20. For 50 amp rig cost is double, plus you need to build a splitter.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
Shotgun
CA
sorry for his loss,
but that is why everyone needs to check the outlet before plugging into anything.
volt testers can be cheap, ins.
Hunting is not a hobby. It is much more life sustaining than that.
Dale-pilot, Jeanette-co-pilot
Electrician since 1978
2003 30' Sprinter 5er
2001 Dodge CTD
psneeld
Cape May, NJ
Sounds like he just got a bunch of new stuff courtesy of the campground...
though it's a shame for the campground management and the loss of the stuff in the rig till it's replaced....
Laura & Scott Neeld
2004 Arctic Fox 29-5T
2001 F250SD EC PSD 4X4, Prodigy, Pullrite Superglide, Timbrens
GBlack
Evansville, Indiana
Anybody care to provide a link to such a tester? I'm looking for something that is plug-in. I know about the Surge Guard and Progressive Industries models that do much more than simple checking.
Thanks!
tvman44
Southwest Louisiana
I use a voltmeter and a little simple led tester that plugs into a 15 amp receptacle through a 30 to 15 adapter to check the polarity before plugging in my RV.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Shotgun
CA
volt tester
can be picked up at any hardware store
marvmarcy
Polson, MT, USA
I have had a 50A Surge Guard (either #18338 or #18541) in my last three rvs. Available from Camping World for $369 or $299 respectively. If there is any fault in the power, it won't allow power into the rv. I think it is preferable to a tester, because a power problem can occur any time (lightning, brown-out, etc.) and the Surge Guard will instantly shut off all power and won't turn back on until the power is restored and stable for at least two minutes. I was amazed at how many times it shut power off in various places, only to eventually turn power back on when everything was stable. I'm sure it has saved me numerous times.
JMHO
Marv
2001 Volvo VNL42T420, ISX450/1650, super 10sp w/GearMaster
2003 Newmar Mountain Aire 38RLRK
Piaggio MP3 400 scooter
RVing since 1979 - Fulltime since 2000 (mostly CO, MT, NC & Key West)
Retired USAF
Chuck&Gail
I use this. For a 50 amp rig you need two of them (or one and move it), and a line splitter.
Kenneth
Washington, the state
The tester Chuck shows has the added feature of testing ground fault interrupters. A simple receptacle tester (mis-named a polarity tester) does the job well and costs $5-6, and are available in every hardware store. Connect it using your 30 amp to 15 amp adapter. For a 50 amp connection, as Chuck says, you'd need a simple line splitter...PM Chuck for instructions.
