RV.Net Open Roads Forum: Travel Trailers: Another (different) traveling with LP on question
 > Another (different) traveling with LP on question
MaddogBC
Kelowna BC
Posted: 05/04/08 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
Our first trip in the (new to us ) TT is coming up this weekend. I have read several topics on the subject and have decided to travel with the LP on just like we used to with the camper. Father and Grandfather did the same. I have no 12 volt option and running my inverter to power AC will kill the battery by the time we get there. DW has a few foodsafe courses and the thought of poisoning the entire family in a remote area is not very pleasant. My question is: Everyone agrees burning the fridge a few degrees off level is very bad for it, but no one ever talks about what 10 miles of 10% grade will do? Most of our trips involve a lot of climbing and descending, how hard is this on the fridge? Thanks
Rob
kottfam6wi
South Central Wisconsin
Posted: 05/04/08 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
because of the bouncing around, the amonia cannot pool from being off level and will cause no problems.
Joe
Our Family Pictures
Joe & Sky
Chris-9, Emily-5, Jessica-3, Jason-2 (yes-we're done)
"Rallies Attended 9 1/2" (Wahoo!! we're catching up!)
2005 Dodge Ram 2500 Quad Cab 5.9L CTD
2005 K-Z Durango 315BH 5th Wheel (2nd Camper)
aftermath
Washington State
Posted: 05/04/08 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
It is not hard on it at all. I am sure that a few experts will chime in soon and tell you how it actually works. Until then I will give you the sort of, kind of, story.
You have an evaporative system and in order for it to work, the fridge needs to be level to allow of the condensate to flow back to the thing a ma jig. When you are traveling the motion and the rocking of the unit will actually enhance this effect. So, when the gas evaporates (or condenses), it flows easily back to the condensor thing (or whatever) because of the motion of the trailer.
So there you have it. Perfectly clear. Don't worry about the fridge while you are traveling. Once you get to camp,then you need to level.
This, in my opinion, is the best piece of equipment in my trailer. I love my refridgerator.
2008 Toyota Tundra, Double Cab, 5.7L V8
2004 Starcraft 21SSO
Equalizer Hitch
Prodigy Controler
smkettner
Southern CA
Posted: 05/04/08 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
No worries about grades. If the vehicle can pull it up the grade the fridge will be fine.
And yes I have been up a 9 mile 10% grade with my fridge on.
vic46
Red Deer, Alberta, Canada
Posted: 05/04/08 11:21pm Link  |  Quote  |  Print  |  Notify Moderator
Unless you are going to be on the road for a real long time, simply plug in a day or two before leaving, pack up the fridge and hit the road with the fridge off. It is good for a real long time if unopened. The reason you don't have a 12 VDC capability is the fridge does not operate very effectively on 12VDC and this option has gone the way of the Dodo. The 12VDC would usually maintain a cold fridge but going from off takes forever.
Vic
MaddogBC
Kelowna BC
Posted: 05/05/08 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
Peace of mind, thank you very much.
Rob
Still Searchin'
Bend, Oregon
Posted: 05/06/08 08:14am Link  |  Quote  |  Print  |  Notify Moderator
One of our most looked at accessories is the frig temp gauge (basically an indoor/outdoor temp. guage, with wire running into frig). It works on one AA battery, and gives a readout of both the inside frig compartment and also the interior RV temperature. When temps start to get in upper 40's in frig, we turn it on, otherwise we leave frig off. Has worked great for us while traveling all over the USA.
2004 Yukon XL K1500 w/ 5.3L & 3.73 diff.
1989 22ft. Wilderness TT @ 5500# loaded
Member: TTN, Escapees, Good Sam
Just retired, will travel!
