Mr. October
Reading, PA
I learned from my first towing adventure this weekend that I do need to wire my Blue Ox Apollo directly to the battery. It was overwhelming my circuit for my cigarette lighter and popping the fuse. Are these battery direct connections all the same? I assume it is just battery leads run to a cigarette lighter adapter. Correct? Seems the Brake Buddy one is a much better deal then the Blue Ox one and much more readily available. Thoughts?
Pete G. ('07 Itasca Navion 23H - Reading, PA)
OnaQuest
Raleigh, NC
You will need to use a fused connection in either case.
Dyslexics of the world... UNTIE Visit www.Dyslexics.moc
Mr. October
Reading, PA
OnaQuest wrote: You will need to use a fused connection in either case.
I believe both the BB & Blue Ox products have an in-line fuse. The Blue Ox manual stresses the importance of having full amperage available for its power source and the cig. lighter circuit seems to have several things in-line in the vibe.
garym114
Put another power outlet in the CRV, just for the Brake Buddy, direct wired to the battery. The 98 CRV has a 10 or 15 amp fuse(can't remember) for the installed outlet. The BB poped it every time. I put a fuse at the battery and the BB has one built into the plug.
2000 Sea Breeze with 1998 CRV Toad in Dawson Creek - Start of Alaska Highway
Don't Forget - USS Liberty, June 08, 1967
MRUSA
Boca Raton, FL
Anything direct wired to the battery must be fused for safety. Use a larger fuse if you need to, so it won't blow in normal use, and put the fuse as close to the battery as possible.
If you don't fuse this line you are asking for big trouble.
Marc, Boca Raton FL
2003 Beaver Monterey 40' triple slide
Blue Ox TruCenter
Acura MDX toad
Unified Tow Brake
Pressure Pro Tire Monitor
Garmin 2610 GPS
Datastorm D3/7000
Sirius Radio
Tivo on board
ramzfam
Appomattox, Va
Most add-on lighter type receptacles come with an in-line fuse. I had to add one to my Jeep as the Even-Brake system called for a minimum capacity of 15 amps while the Jeep's lighter was fused for only 10 amps.
Have RV....Will Travel
2007 Forest River Sunseeker 2860 LTD
2000 Jeep Wrangler Sahara
